drag and drop from not working max 2023
infoQ32Z4
infoQ32Z4
Max 2023 won't let me drag and drop from explorer. It's driving me insane. How can this be fixed?
miledrizk
Right-click the Max shortcut, Properties, then Advanced, and make sure Run As Administrator is unchecked
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
infoQ32Z4
That doesn't work
grue1970
in max 2022, i just recently started having this problem HOWEVER, it works with 1 running instance of 3ds Max 2022, but if i open a 2nd instance and drag-n-drop a scene file into that instance, it doesn't work.
this is only with scene files that i've seen so far.  i should be getting a pop-up that says open/merge/xref.  i get that in the 1st running instance, but not the 2nd.
3ds Max all versions past and present | GPU Rendering on 2 machines | Standard, MentalRay, MentalRay IRAY, IRAY+, VRAY, Arnold
Diffus3d
Out of curiosity, are you dragging and dropping from the desktop, network locations, or C:/ root?
Best Regards,
