Max 2018 will not start when the DCC link plugin is installed.
If I uninstall the DCC link program, from Windows control panel, Max will start normally again.
3ds Max Interactive seems to work with or without the DCC Link app running.
3ds Max 2018 will not launch at all when the DCC plugin is running. Event log says fault in module "ExchangeStorePackageManager.dll"
When Max 2018 is running. the "Interactive" menu item jumps to the webpage about installing 3ds Max Interactive.
So, the docs say that these two apps should work together, but in my case they absolutely do not. Any help here would be appreciated.
Solved by foglevel. Go to Solution.
Solved by WojtekOgrodnik. Go to Solution.
Same problem here. Even uninstall/ re-install of Stingray & 3ds Max won't solve the problem.
Back to the FBX export 😳
do you also have the stingray dcc installed?
if so this needs to be uninstalled
DarrenP
i also ran into this when i had both the interactive dcc & the stingray dcc installed and this prevented Max 2017 & 2018 from launching uninstalling either the Interactive dcc or the stingray dcc fixed this issue
but then i got error message in 2018 about a max script
doing this: removing your ENU folder under "C:\Users\<username>\AppData\Local\Autodesk\3dsMax\<MaxVersion> and restart Max.
fixed the issue
If you already have stingray installed on this machine you really don't need 3ds Max interactive installed
DarrenP
Hello @Anonymous and @jordi_bergboer,
I am currently collecting information about these problems. I have had about 6 reports (including the two of you) about the DCC link or Max not starting when they are installed and I wanted to ask if you'd be willing to email me your event viewer logs, please? Alfred.Deflaminis@autodesk.com.
We had another issue with connection between applications resolved by updating DirectX but it wasn't specifically a DCC link issue. It might be worth trying in case this is the commonality between the two issues until I have a better sense of what is going on here.
Which OS are you two using?
Thanks very much and best regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
@jordi_bergboer have you tried deleting the "C:\Users\<username>\AppData\Local\Autodesk\3dsMax\2018 - 64bit\ENU" folder?
@Anonymous.bergboer wrote:
BTW, the interactive menu says: get max interactive. That's all??
yes its because it looking for the Interactive DCC plug in
DarrenP
@jordi_bergboer Could you PM me your email address. I'd like to send you a different installer and see if it works.
Hello all, can you please confirm with me that you've installed Update 1 for 2018 prior to installing Max Interactive? Thanks very much!
Best Regards,
Best Regards,
yes the update was installed first
DarrenP
Thank you both for the confirmation.
Best Regards,
Same problem here, Max won't start with DCC. Update installed first. With dcc uninstalled both max and Interactive work but no link between them...
Hello @WojtekOgrodnik and everyone else,
This is a new issue for me, and I think that the best thing here is for me to collect all the information I possibly can. I have some questions below which may help me narrow this down. Thanks for taking the time to answer them.
1) Which OS are you using, and in what language? Does your windows username contain any special characters? (Æ, É, Ñ, etc.)
2) What language do you run 3ds Max in?
3) What is your current permissions level in Windows? Any group policies in place? What about your current UAC level?
4) Do you see anything strange in your event viewer logs?
5) Would you mind emailing me the application and system logs? (no biggie if not, but if so please email them to alfred.deflaminis@autodesk.com)
Thank you very much for taking the time to do that.
Best Regards,
For me it is:
1) Windows 10 Pro English
2) English
3) Admin
UAC - 3
No policies
Will update 4 and send 5 later,
Thank you!
Thank you for doing that @WojtekOgrodnik.
@jordi_bergboer has been emailing with @electrotoast_old and a he'd mentioned that adding:
C:\ProgramData\Autodesk\ApplicationPlugins\StingrayDCCLink_Max2018.bundle\Contents
To the systems path ->3rd party plugins fixed this problem for him. To the other users in this thread, will you please try that for me? Thank you very much!
Best Regards,
