Creating a texture map in 3DS Max 2015
Hi all,
Can someone tell me the way creat this map (attached)
Your post subject line has been edited by @hagen.deloss: Creat map
Accepted solutions (3)
hagen.deloss
Hello @Anonymous
Thanks for posting your question on the forums! Would you mind clarifying what you would like to do with the image?
If you want to map the image as a texture, here is an article on how to texture map using 3DS Max.
Looking forward to hearing back from you!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
hagen.deloss
Hi @Anonymous
I wanted to check back and see if my post helped you with your problem. It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process
Also, what version of 3DS Max are you using for this project?
Hagen Deloss
I don't mean use assign material, I mean creat textures. How can I creat texture following photo posted #1. I use 3dmax 2015.
hagen.deloss
Hi @Anonymous
3DS Max has a feature called the viewport canvas that you can use to create texture maps right in the viewport! It' snot the most robust tool, but it gets the job done, here is a tutorial on how to use it.
[video]
If you are looking for a more extensive toolset for texture creation, I would suggest Adobe Photoshop or another 2D image creation tool.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
I think I know this way creat map for street and some map.
My problem fix by photoshop.
Thank you for your time.
Smiley Happy
hagen.deloss
@Anonymous
Thanks for the update, that render looks amazing! If you haven't seen, a lot of users are sharing their renders and 3D work in the 3DS Max project showcase thread, would love to see this render, and whatever else you have made in Max in there!
Hagen Deloss
