I am attempting to scatter multiple grass objects on a flat surface, but while distributing them, only the first object remains vertical while the rest are distributed horizontally. Does anyone have an idea about what might be causing this issue?Only 1st Object is Vertical, the rest are Horizontal.
Solved by goulnazarianh. Go to Solution.
You need to fix the pivot points of the scatter objects. Some have the Z pointed up, and others have the Y pointed up. Under the Hierarchy tab of the Command Panel, you can adjust the pivot easily by clicking the Affect Pivot Only button (with your grass clumps selected) and then click the Align to World button.
Chris Medeck
I've already done that, but the grass started to appear upside down.
So I tried rotating the plane 180 degrees, but after the rotation the grass remained horizontal.
Eventually, I found the solution by clicking on "Reset X Form" to fix the issue.
Anyway, thank you for your time.
