3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Copy and paste file location links
6 REPLIES 6
sam.palmer3KKVR
1512 Views, 6 Replies
Being able to copy and paste a file explorer location link and paste into the Save File As location instead of having to trapes through your entire folder structure to save something...
6 REPLIES 6
Diffus3d
in reply to: sam.palmer3KKVR
I do that every day... works like a charm.   If you paste the path then hit enter once, it goes to that path and lets you continue to name the file normally.  Been doing this for decades...
Best Regards,
Alfred (AJ) DeFlaminis
View Max Tips/Tricks Megathread
Are you sure? Maybe I'm in the wrong place but if I select the path link at the top there is no way of pasting the location link in there?
Diffus3d
Replace the file name with the path and then hit enter.  Then, it gives you your file name back and you can hit enter again to save in that new location. 🙂
Best Regards,
sam.palmer3KKVR
in reply to: Diffus3d
Oh my goodness I've just found how to do it... It is so un obvious but it worked! Thank you aha, saves so much time
Diffus3d
Handy isn't it?  🙂
Best Regards,
I was today years old when I found about this!
Thank you!
