Being able to copy and paste a file explorer location link and paste into the Save File As location instead of having to trapes through your entire folder structure to save something...
Solved by Diffus3d. Go to Solution.
I do that every day... works like a charm. If you paste the path then hit enter once, it goes to that path and lets you continue to name the file normally. Been doing this for decades...
Best Regards,
Alfred (AJ) DeFlaminis
Are you sure? Maybe I'm in the wrong place but if I select the path link at the top there is no way of pasting the location link in there?
Replace the file name with the path and then hit enter. Then, it gives you your file name back and you can hit enter again to save in that new location. š
Best Regards,
Oh my goodness I've just found how to do it... It is so un obvious but it worked! Thank you aha, saves so much time
Handy isn't it? š
Best Regards,
