Hello friends,
My name is Aarundh and I'm an architect from India. I have installed 3ds max to create great walkthrough and renderings. After learning from some Youtube tutorials I'm not able to link revit model in 3ds max.
I have tried all ways like to Import from .rvt, Export from revit and link a revit or .fbx file in 3ds max.
I cannot see my model in 3ds max, I am getting this message (attached) everytime. Please help me guys! I am in deep trouble.
Hello @Anonymous,
I'd like to help you with your problem here, and I have a few questions for you. Which version of max are you using currently? There are some revit plugins that you may need to install depending on which version you are using. Also please note that except for 2017, 3ds Max isn't fully compatible with windows 10 as windows 10 came out after the development of 2016 and before. However, this may not be the issue and I'd like to take a deeper look into your problem. Please keep me posted!
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @Anonymous,
I wanted to follow up here and see if you are still having issues. Is your Revit and 3ds Max the same version?
Thanks and best regards,
