I've been trying to work out how to re-enable the 'Send To' function since installing Max 2017.
While searching I came across this:
"When using the Send To feature in 3ds Max 2017, it will not send to previous versions (I.E.: Maya 2016). If you are having an issue related to this please contact Autodesk® Support."
I'm guessing that Mudbox 2016 also comes under this bracket, but if there is a way around it I'd love to know. Any help much appreciated!
Solved by Alfred.DeFlaminis. Go to Solution.
Hello @Anonymous,
I'd love to help you get this working so you can Send To between apps. I recently wrote up a post about this here, and there are links here and here that can help explain the process to you in more depth. Though my first link above is technically about Motionbuilder, the process is the same for Mudbox. Please let me know if you have trouble and I'll be glad to help you in any way I can.
Please hit the "Accept as Solution" button if my post fully solves your issue or answers your question. This lets me know that I was effective in helping you, and thank you for doing so.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @Anonymous,
Best Regards,
Hello @Anonymous,
Just following up on this, did you get this worked out?
Best Regards,
Hello @Anonymous,
Best Regards,
