- Mute
- Permalink
- Report
There is bug in Max 2018. When I merge a .max file created in older versions of Max to Max2018 and merged file system units are different than the current system units then I have empty Layer Explorer list. And there is no way to show merged objects in this list. If I switch Scene Explorer to Hierarchy mode then I see objects. If I press 'H' to select an object in the scene I see all objects. But Layers list doesn't show merged objects.
I attach a test file. The system units of the file are inches. To reproduce the bug set the Max2018 system units to meters or centimeters and merge the provided file. Open Layer Explorer. You will notice that the Layer Explorer list is empty.
If I open provided file instead of merging with auto conversion of units then Layer Explorer works fine after that.
