3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Body Objects make sometimes strage corners
1 REPLY 1
L_Moeller
224 Views, 1 Reply
Hello
I import STEP data as body objects. I then render these using a farm. In some images, some vertecies shift strangely in space, creating corners that shouldn't be there. When I render the image again, the data is fine. It seems like some vertecies are not sitting in the right place. How does this behavior occur and how can I turn it off?
I work with Max 2023 And BackBurner to control the Farm.
Labels (5)
1 REPLY 1
Diffus3d
in reply to: L_Moeller
That is weird.  I can only guess here.
1) Double check the farm machines have all the same updates to 3dsmax and the renderer.
2) Somehow the body objects are being interpreted differently by a machine, maybe due to a timeout or load time or who knows.  Some things that might help:
  1. Put an edit poly on top, should make the vert positions concrete.
  2. Try to weld the verts on the body object.  (If you haven't already.)
  3. Try a higher detail level on the body object.
Chances are one of those things will do the trick.
Best Regards,
Technology Administrators
