Batch Save Selected
Batch Save Selected
matt.wilmot
Batch Save Selected
matt.wilmot
Hello.
Is there a way in max to Batch "save Selected" on objects ? Or maybe a script?
I have a scene with many objects.
I want to select all objects and save them out individually as separate max files.
It will take quite a long time to go File>Save Selected on each one.
Thanks for any help.
miledrizk
I created now this small macroscript that will help you do what you want.
Install it and create a toolbar for it. you'll find it under the category "autodesk_forum"
Here's the script:
https://drive.google.com/file/d/1_kZvSHhVc4WtxpWGycxei2VTB3g8trg2/view?usp=sharing
If you never installed a macroscript before, here's a tutorial i made on Youtube to show you how:
https://youtu.be/kvaAY8TCRdo
Note: for the script to work you need to select at least one object. After you select click the button
A dialog will ask you for the folder you want to save your object in.
After selecting the path Max will save each object in a separate file using each object's name
As the file name
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
matt.wilmot
WoW!!!
That is an absolutely perfect solution my friend.
Thankyou very much!!!
claudiosdr
Observer
Observer
Hello good afternoon. Can you activate the link please? a lot to use this script, from now on
miledrizk
Sorry for the late reply,
Here is the link for the script:
https://drive.google.com/file/d/1-HfEBcz5ONLYgQkS3nqbI-eAA5Tg0H9V/view?usp=sharing
You need to look into the category called: "MiRi-Tools" instead of "autodesk_forum"
miledrizk@gmail.com
claudiosdr
Observer
Observer
It was not too late, I accepted for the attention and for a while for me to re-send the script. Thank you very much
laura.soen
I have a bit the same problem, but I need to save my objects in batch to separate JPEG files. I have all my objects in a certain viewpoint and want to make JPEG files of all of them separately. Do you maybe also have a script for this kind of problem?
Thanks a lot!
