I just want to add that if you are using Vray you should also always use Vray Shadows...
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Reduce the Length Of Folder name & File Name.
And reduce the Lengthy Sub - Directories ( Ex: Drive :// ****/ ****/****/****/****
