Baking DIFFUSE Map with render to Texture
Hey guys,
                  I am trying to bake a diffuse map onto this simple object, everything is set up, I am baking from high to low poly, low poly UVs are all set up and projection modifier is applied etc.
                  I know how to bake normal maps, AO maps etc but for some reason when I go to bake a Diffuse map only the sides that face the camera are showing in the final image and sides facing away are black.
                  I have attached the normal map to show that is baking as intended, and then also the diffuse map with the problem I am describing.
                  Anyone know what I am doing wrong?
Hey Guys,
                  After about 2 hours of trying before I posted I took the Complete Material off the object and assigned just the diffuse via the Standard (Legacy) Node in material editor, and then baked it and it worked. I still need to learn how to bake with Arnold so if anyone has any links to a useful guide to baking using Arnold that would be appreciated. Marked as solution to this problem.
Mark
carlos25lb
Observer
Observer
Man, You dont know how much you helped me, I have been for 4 hous just trying random stuff, LOVE U!
