Announcements
How do I instantly create a new vertex with a centered point?
I'm used to using C4D, and I liked how you can grab an edge and instantly create a new vertex that was perfectly centered. In 3DS max, I have to select insert vertex and it just goes on wherever it wants...
Also, C4D let me slide a vertex along an edge without any distortion and it followed the line... does 3ds max have something like that?
BenBisares
Autodesk Support
Autodesk Support
For the first one question I would set the snapping to "Midpoint" and then enable snapping before you insert a vertex.
For your second question, in the Edit Poly modifier you can set the constraint to Edge or even Face depending on what you want.
Ben Bisares
Also, C4D let me slide a vertex along an edge without any distortion and it followed the line... does 3ds max have something like that?omegle xender
thankyou my issue has be sound
