10:46 PM
Hey guys,
I am trying to bake a diffuse map onto this simple object, everything is set up, I am baking from high to low poly, low poly UVs are all set up and projection modifier is applied etc.
I know how to bake normal maps, AO maps etc but for some reason when I go to bake a Diffuse map only the sides that face the camera are showing in the final image and sides facing away are black.
I have attached the normal map to show that is baking as intended, and then also the diffuse map with the problem I am describing.
Anyone know what I am doing wrong?
