Backburner manager not working : "could not bind private multicast sockets etc."
Message 1 of 25
Hi everyone, i have an issue when i try to use backburner in my PC, for simultaneus rendering. But when i try to start the BACKBURNER MANAGER i have some errors as show an image attached . It's sound like this old post, which never been solved http://forums.autodesk.com/t5/3ds-max-3ds-max-design-general/need-help-with-backburner/m-p/4976680/h... someone have solved this issue ? Thanks
Replies (24)
Message 21 of 25
Alfred.DeFlaminis
Message 22 of 25
Hi, come back from holydays I just tried your last solutions but not working. But before forward the issue to other forums, i've tried the usb wifi device in another PC with BB installed, and latest driver (of usb wifi). And not working too !! Do you have another suppositions ? i'll try your last advice, but i want try to install on my pc a PCI express WIFI card at this point, the situation is becoming unsustainable. i will keep you updated Best regards
Message 23 of 25
Alfred.DeFlaminis
Hello @Anonymous,
Thanks for the update.  I will see if IT has a USB external WIFI device that I can also test on in the meanwhile.  Thanks for keeping me posted.
Best Regards,
Message 24 of 25
Hi
I've good update for this issue.
as i said in the previous post, i tried to install an pci express wifi card on my PC ( this device http://www.tp-link.it/products/details/cat-11_TL-WN881ND.html )
and
IT WORK !! finally !!!
i have no idea what doesn't work with the usb wifi device, but i think it was the driver ( or the cheap usb device )
Thanks for you help and patience
Kind regards
Filippo
Message 25 of 25
Alfred.DeFlaminis
Hello @Anonymous,
YES!   I am so glad to hear that!  Heart
Thank you for taking the time to communicate back and forth with me while you and I worked on this issue.  I really appreciate your time and dedication and you stayed patient the whole time.  I can't thank you enough for letting me know about the resolution for this issue as well.  Have a great weekend and if you ever need anything you know where to find me!
Best Regards,
