3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
alembic export from point cache loose uvs
5 REPLIES 5
1924 Views, 5 Replies
hello
when I export an alembic file fro a point cache 3dsmax object, and load the abc, there is no more uvs...
5 REPLIES 5
santd
Thank you for posting to the Area forums.
Does using the option to Import to the scene root make a difference? I am mainly a Maya user, but trying to help out with 3ds Max and I have had this option make a difference on the Maya end.
I hope that information is helpful.
Cheers,
David Santos
in reply to: santd
Hi, thanks for answer.
In max i use alembic object creation, where I don't see any options.
So I tried to import alembic, and see an import option with scene root option checked.
But no success... 😞
When I was playing with alembic files from point cache, if I remember well, it seems that max keep uvs for the first frame (so the base object) but loose uvs for other frames (modified object).
santd
I looked in our internal database and we currently have an opened change reqeuest which our development team is looking into a resolution for.
As a workaround you may be able to use Maya. If you don't have a license you could download a trial.
Cheers,
David Santos
I found that exporting as Alembic using the HDF5 format instead Ogawa seems to preserve UVs in Max 2016.
I also found that exporting to Alembic from 0 to 100 will cause your animation's xform to be wrong at frame zero. Export -1 to 100 and uncheck 'fit time range'.
