Yeah, doesn't seem they spent much time with the feature. Not prime time as usual.
Zooming sucks. not smooth. (have to select the +/- zoom tool first)
Panning with 2 finger swipe? nope, not working here on a Dell XPS 27 touch display.
Return to Home Position with 2 finger double tap...nope.
Cannot get the others to work properly either.
Will have to try with the Wacom tablet later.
it figures, horse$hit, incomplete feature again, doesn't fully work with touch displays even with Enable Touch Navigation on in preferences:
3ds Max can recognize gestural input from your multi-touch device, meaning you can work with a scene using simple finger taps and hand gestures.
3ds Max supports the following multi-touch devices:
To use 3ds Max with your multi-touch device, ensure that Enable Touch Navigation is turned on. This option is on the panel Customize Preferences Interaction Mode. If your setup includes a supported multi-touch device with the latest drivers, no additional configuration is required.
Hi
Is there any opportunity to make it work fine?
This feature should be very convenient!
