3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
adjusting angle of object
4 REPLIES 4
451 Views, 4 Replies
how do you correct or adjust the angle or angles of objects ? example attached of 2 cylinder legs post mirrored  with image in rear .
4 REPLIES 4
RobH2
Right click on the object and choose "rotate." You'll see the rotation gizmo. Click and drag on the correct axis indicator and the object will rotate.
Now, you can change the position of the axis so it rotates from the point you want it to. But I'll leave that to you to look up in the documentation. It's easy to find. That way you'll get used to using the documentation. You'll need to get used to using it to progress with Max. Max is intuitive up to a level but quickly you'll get to where you can't proceed without reading.
But, this should get you started.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
in reply to: RobH2
the tutorial links you mentioned did not appear , pls add the links .tks
RobH2
This will get you started. http://help.autodesk.com/view/3DSMAX/2019/ENU/?guid=GUID-CE714983-3FCD-4C76-BB3A-7B2C5B0C4F5E
Finding tutorials on the basics of Max is not difficult. Google (3ds max modeling) it and use the documentation. If you don't figure out how to do it yourself, you will never master the program. It's very powerful but it's not easy to master. It takes a lot of time. I encourage you to be creative in searching for help. It will be necessary for your success.
Rob Holmes
in reply to: RobH2
i will use bend before mirror as well . tks links .
Technology Administrators
