3ds Max - Projecting splines onto obecjts as non destructive modifiers
This widget could not be displayed.
I'm new to 3ds max, so there might be an obvious answer to this that I haven't been able to find:
Is there a way to project a spline onto an existing surface similar to the function of a modifier? Meaning that editing the source spline or the objects on which the spline is projected changes the projection of the spline instantaneously. A non destructive spline projection modifier so to speak.
I've tried the "Glue" plugin as well as using compound objects > shape merge, but both of these options give me a second, new spline rather than an adaptive projection of my existing one.
Combining an adaptive projection modifier with the use of RailClone or Forestpack would be a very handy tool, as everything generated by RC/FP would update automatically when changing the parameters of the projected spline (rather than having to edit RC/FP objects by picking a newly made spline after projecting via Glue or shape merge.)
Does the described function exist? If not, I think it would quite a powerful addition to the modifiers in many different scenarios.
Cheers!
RobH2
I think what you are talking about is a bit more parametric integration into Max, kind of like what you can do with CAD software where you and make big changes by driving a parameter. There is obviously some of that already in Max with a number of modifiers, but, they only reach so high and eventually, they  just make messes farther up.
You should clarify your ideas a bit more and write them out with some specifics and post it to the "Ideas" forum. I think you may have some supporters.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
