3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
3ds Max hardware
2 REPLIES 2
646 Views, 2 Replies
3ds Max hardware
Hello all,
I'm planning on using 3ds Max, AutoCAD and Revit quite a lot in the future so I figured I'd get myself a decent rig. Since I'm a bit financially challenged I can't afford anything very fancy. This is the setup that I came up with:
-Gainward nVidia GeForce GTX 1070 8GB DDR5
-Intel Core i7 8700 3,20 GHz, LGA1151 BOX, Cofee Lake
-Crucial 16GB 2400 MHz DDR4 RAM
-Samsung SSD drive 500GB Evo 860 V-NAND, MZ-76E500B/EU
Do you thing this is a good setup which will allow for comfortable usage of primarily 3ds Max?
Tags (2)
2 REPLIES 2
This setup is absolutely perfect. A CPU cooler is highly recommended as the CPU will get hot if used for rendering.
I'd recommend the Cooler Master Hyper 212 Evo. It's tried-and-true and budget-friendly.
Hope this helps.
Best regards,
Joseph B.
Thanks a lot for the reply Joseph!
