Hi
Just installed the latest Autodesk 3Ds Max 2019 and experienced something new every time after closing the app. W10 gives me this warning..which is related to Protected Folders setting from W10.
I'm trying to figure out what 3dsmax.exe is trying to modify there.. in my case it's about these folders.
Solved by hagen.deloss. Go to Solution.
Thanks for bringing your question to the forums! I'm wondering if you could add 3DS Max 2019 to the exclusions list in Windows 10, here is an article walking through how to do that.
I would recommend you check your file paths in 3DS Max by going to Customize>Configure System Paths and see if for some reason any of the paths are set up to the folders the Windows Defender is protecting.
Additionally, I would recommend resetting your 3DS Max user preferences back to default, here is an article walking through how to do so.
Keep me updated on how this goes!
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Did all that was recommended..seems to be ok. The exclusion I think that did the job actually.
Thanks!
Happy that worked out! Feel free to post to the forums any time you need help with a feature, or advice on how to use 3DS Max's tools 😄
Hagen Deloss
Thanks for support and this good reception 🙂
