You should try using the batting linetype. If that doesn't suit, then, if you want a
linetype, you need to create the shape(s) you want to use, compile the shape file, and
then create a linetype from the shape(s).
I don't think there is any worthwhile lisp method to do all that. But after you have the
linetype, lisp can load it easily.
t"Martin" wrote in message news:5783168@discussion.autodesk.com...
I was wondering one thing.Using Alisp, how can i do suvh an
linetype(attached file)?
M
