Visual LISP, AutoLISP and General Customization
Close SSM and 7 lines visible at CMD line
2 REPLIES 2
steelcitymetal
216 Views, 2 Replies
I need a lisp that will, upon ACAD startup:
1) Close the Sheet Set Manager Palette
2) Make 7 lines visible at the command line
and 3) (if possible) Dock the Properties Palette to the right (it opens up un-docked)
I know you can set the environmental variable "CmdVisLines" to a desired number, but when I re-open ACAD, it constantly resets the value to 3.
2 REPLIES 2
in reply to: steelcitymetal
(command "._sheetsethide") will do #1.
But creating the proper workspace and restoring it at
startup should do all three.
(command "._workspace" "_C" "MyCustomWorkspace")
R.K. McSwain
http://rkmcswain.blogspot.com
Thanks for the sheetsethide command, that worked like a charm.
As far as workspaces are concerned, however, I am only using 2005, so we don't have them.
”Boost
