Undo Command to not change view state
Ok this used to bother me in AutoCAD... years later it outright makes me INSANE in Revit.  When I want to cycle undos and redos, I don't want the view state (angle, zoom, etc) to move AT ALL.  In other words, when I click undo/redo, I'd like to see/verify the results in the exact context of where I am looking.  What I don't want (which is the current method) is to click undo/redo and the view jumps to some unknown angle, and I have to find what I was looking at.  Do this a few times and it's a real inconvenience.
Undo/Redo should only relate to the objects themselves.  Leave Rewind for view states.
8 Comments
dplumb_BWBR
And allow a Keyboard Shortcut for Rewind!
That's the ONLY thing I use the Steering Wheel for.
Rewind should be available on the View Ribbon.
mononull
Did you ever figure this out or is it just not possible?  I work with the Revit API so I'm building systems in stages.   When my program is done I can undo each stage (through the UI) to view how adding or removing family instances is affecting other things.  While I'm undoing and redoing all the actions I want to be able to zoom in on areas without losing my undo history.  Most of the time because the view history is associated with changes to objects it makes it impossible for me to step through each of the rendering stages to see what's going on.
Agreed, Not sure if this is bad coding or what. But then Revit has many many issues like this.
SRaynorZWFK9
It's almost like Autodesk has no experience using their own products. For the record, the changing view states is incredibly annoying.
hughecchapman
Is there a fix/workaround for this..?
The lack of an option to remove view state changes from the undo stack is one of the things I find incredibly annoying about AutoCad. Don't tell me it's the same in Revit 😭
zainab_suhrawardy
Community Visitor
This is literally the most goddamn retarded thing about Revit. Why the FACK does it do that and why has Autodesk not fixed this????
cheyneross
Observer
I have the same problem, I undo a step and it also undoes all my view movements. So if I was zoomed way in on that step, it snaps to that zoom window and I can't see what actually changed. Frickin annoying.  REVIT WE NEED A FIX.
noahCHT4G
Unbelievable that there's no fix for this yet.
