Revit Default Manager
A possible add for a Revit Default Manager under the Manage Ribbon tab to gain control of the common Revit Default settings.
Such as:
Current Phase for newly created Views/Schedules
Titleblock family
Move the tag defaults here
Viewports that get dragged on a sheet
Link Insert defaults (Automatic - Origin to Origin)
etc....
If anyone can expand this list of default controls, please share... Smiley Very Happy
10 Comments
lionel.kai
How about adding stuff like:
  • creating Walls by Height instead of Depth
  • whether Mirror resets to Copy every time, or remembers your previous setting
  • keeping Constrain OFF instead of randomly getting re-checked
A paradigm for this exists  for Tags - where you can choose default tag per category.
I would like to be able to change the text that appears in the "scale" label when a sheet has different scales on it  (now this is hard coded "As indicated" but our titleblocks use all caps...)
lionel.kai
and an "ignore legend scales" switch so putting legends on a sheet with a plan would still show the plan's scale
also here:
http://forums.autodesk.com/t5/revit-ideas/custom-text-in-scale-parameter/idc-p/6377987#M1018
lionel.kai
both of these get remembered within the Revit session (like the Wall/Column by Height/Depth setting), but it would be nice to not have to think about it the first time:
  • have Leader unchecked by default (for tags)
  • be able to set leader anchor points (for text) - ex: Leader at Top Right
lionel.kai
set default DC & AS (when the project is opened) instead of last loaded, per:
http://forums.autodesk.com/t5/revit-ideas/template-building-set-default-family-upon-tool-selection/i...
(but w/in each session it still would remember your "last-used" setting)
leader on/off for dimensions
Ability to change the default annotation crop size for sections, elevations, etc.
lionel.kai
I now think the "ignore legend scales" would be better implemented this way:
http://forums.autodesk.com/t5/revit-ideas/prevent-sheets-to-pick-up-the-scale-of-legend-views/idi-p/...
These seem like suggestions for improvements for the revit.ini file and a better process for sharing across an organisation those settings.
For default view title, it is the one with the lowest element ID, easiest way to control it is figure out which one is the default and rename then edit it to be the one you want in your company template.
