I am try to create a new family using the wall cabinet template, so I can clicking on families>new. But, it says that the folder is empty! What do i do?
Hi gontebri, you are getting this error because your folder does not have any template. You need to copy family templates within that folder.
Hi, Revit did not install properly in your system. You need to re-install Revit again. When you will install Revit, you have to select the check box for ‘Revit Template’, and then the templates will be installed within the folder. Otherwise you can download templates from internet. You can check www.revircity.com, here you will get lots of templates and you also can download them.
