making new families
6 REPLIES 6
580 Views, 6 Replies
making new families
  I am try to create a new family using the wall cabinet template, so I can clicking on families>new. But, it says that the folder is empty! What do i do?
6 REPLIES 6
BIMAbhi
Can you check mark on the Template & Library when installing the software.
Thanks & Regards
BIMAbhi
in reply to: BIMAbhi
do I have to reinstall the software? or is there somewehere on autodesk i can reinstall them?
Hi gontebri, you are getting this error because your folder does not have any template. You need to copy family templates within that folder.
where do I find the family templates though?
Hi, Revit did not install properly in your system. You need to re-install Revit again. When you will install Revit, you have to select the check box for ‘Revit Template’, and then the templates will be installed within the folder. Otherwise you can download templates from internet. You can check www.revircity.com, here you will get lots of templates and you also can download them.
Thanks! I reinstalled the software and that did the trick
