I'm writing an event handler to trap a polyline being modified with the ObjectModified Event. Right now it works but when I grip edit the polyline I sometimes get only one event fired but sometimes I get multiple events fired. It seems like when I get multiple events fired I get one for every grip...or one for each vertex and each segment?
Any suggestions on how I can trap just the last event? I only need the polyline for reading once it is completely updated. Or, I suppose if I could trap a vertex changing somehow then I could do something with that.
Thanks.
What you could do is to handle the modifyed event and add the objectid from the entity to a list. And check if the list has the objectid then don't add it.
Then handle your code your code in the command ended event itterate true the list. And then clear the list..
Hope this helps. This senario can be used when you need transactionhandling in autocad events.
Kind regards,
Irvin
I'm new to autocad custimizatin and I'm trying to capture the object modified event for attribute change. It sounds similiar to what your doing. Is there anyway you could give me a sample of your code to get me started. I'm using vb.net
Dave
Dave,
Here is some code. I tried to strip out all the custom classes and dependencies specific to my usage. What's left I beleive may be helpful to you. I used ideas and code snipits from reading other posts on events. Another specific contributor that is notable is arcticad and his reply on "Document Change Event".
Good luck.
{code}
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Public Class AppEventsClass
Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
Private mIdCol As List(Of ObjectId) 'a collection of ObjectId's for use in the command ended event handler
Private DocMan As DocumentCollection
Private db As Database
Private doc As Document
Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
mIdCol = New List(Of ObjectId)
DocMan = Application.DocumentManager
AddHandler DocMan.DocumentCreated, AddressOf callback_documentCreated
initEvents()
End Sub
Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
RemoveHandler DocMan.DocumentCreated, AddressOf callback_documentCreated
RemoveHandler doc.CommandEnded, AddressOf callback_CommandEnded
RemoveHandler db.ObjectModified, AddressOf callback_ObjectModified
mIdCol.Clear()
End Sub
Private Sub initEvents()
For Each doc In DocMan
db = doc.Database
AddHandler doc.CommandEnded, AddressOf callback_CommandEnded
AddHandler db.ObjectModified, AddressOf callback_ObjectModified
Next
End Sub
Private Sub callback_documentCreated(ByVal sender As Object, ByVal e As DocumentCollectionEventArgs)
initEvents()
End Sub
Private Sub callback_CommandEnded(ByVal sender As Object, ByVal e As CommandEventArgs)
If mSIdCol.Count > 0 Then
Dim ObjID As ObjectId
For Each ObjID In mIdCol
Dim Struct As New cStructure(ObjID)
Struct.Rebuild()
Struct = Nothing
Next
mIdCol.Clear()
End If
End Sub
Private Sub callback_ObjectModified(ByVal sender As Object, ByVal e As ObjectEventArgs)
If Not mIdCol.Contains(e.DBObject.Id) Then
mIdCol.Add(e.DBObject.Id)
End If
End Sub
End Class
{code)
Hi
Thanks for the help. I've gotten as far as getting the objectmodified event to fire, but I'm not sure how to filter for which command was used or how to tell if an attribute has been updated. Do you know of any books or sites that might be helpful on this subject? I got vb.net programming level 1 by Jerry Winters, but there's not much in it on event handlers
thanks again for your help
Dave
You can check for an attribute in the ObjectModified even handler. Test e.DBObject.Id.ClassName. If it matches what you're looking for you can add to the collection.
I don't have access to my documentation but there is a Property or method in the CommandArgs for the command name.
If you download the ObjectArx documentation you can find lots of information.
Sorry, Should have been e.DBObject.Id.ObjectClass.Name.
My code reads
If e.DBObject.Id.ObjectClass.Name. = "AcDbPolyline" then
''do some stuff to polylines
End If
I downloaded the ObjectArx 2012 documentation and it has some new stuff in the Managed Class Reference.
Still having trouble with this. I've gotten the object modified event to fire but it fires about 15 times every time an object is modified. Any clue as to why this is happening?
Can you post your code to look at?
The ObjectModified will fire a lot. There are many things that will cause this to fire on the same object. Not to mention that it fires no matter which object is modified. That's why I added the collection to hold the ObjectId of the entity I wanted to trap. Then I handle it once in the command ended event.
AddHandler myDB.ObjectModified, AddressOf callback_ObjectModified AddHandler myDoc.CommandEnded, AddressOf callback_CommandEnded End Using End Sub Private Sub callback_ObjectModified(ByVal sender As Object, ByVal e As ObjectEventArgs) Dim myBlockRef As BlockReference = e.DBObject.Id.GetObject(OpenMode.ForRead) Dim BTR As BlockTableRecord = myBlockRef.BlockTableRecord.GetObject(OpenMode.ForRead) MsgBox(myBlockRef.Layer)' & vbCr & BTR.Name) If Not IDList.Contains(e.DBObject.Id) Then IDList.Add(e.DBObject.Id) End If End Sub Private Sub callback_CommandEnded(ByVal sender As Object, ByVal e As CommandEventArgs) If IDList.Count > 0 Then Dim objid As ObjectId For Each objid In IDList MsgBox("aaaaaaahhhhhh") Next IDList.Clear() End If End Sub
Here is some of the code (basically copying yours) I'm not sure how to test for the block name and layer of the object I modified. Like I said I'm really new at this and appreciate all your help. I'm still at the point where I have to add these events manually with the netload and commandmethods. I'd be willing to pay you for some phone help if this is to much to accomplish through email.
once again thanks for your time
Dave
Private Sub callback_ObjectModified(ByVal sender As Object, ByVal e As ObjectEventArgs) Dim trans As Transaction = e.DBObject.Database.TransactionManager.StartTransaction Try Dim obj As Object = trans.GetObject(e.DBObject.Id, OpenMode.ForRead) If obj.GetType.Name.ToString = "BlockReference" Then If Not IDList.Contains(e.DBObject.Id) Then IDList.Add(e.DBObject.Id) MsgBox(obj.GetType.Name.ToString) Dim myBlockRef As BlockReference = e.DBObject.Id.GetObject(OpenMode.ForRead) Dim BTR As BlockTableRecord = myBlockRef.BlockTableRecord.GetObject(OpenMode.ForRead) MsgBox(BTR.Name) End If End If Catch ex As Exception End Try trans.Dispose() End Sub Private Sub callback_CommandEnded(ByVal sender As Object, ByVal e As CommandEventArgs) If IDList.Count > 0 Then Dim objid As ObjectId For Each objid In IDList MsgBox(e.GetType.ToString) Next IDList.Clear() End If End Sub
I got a little farther than earlier but I'm still not sure how to get blockref name in the commandended event
Dave,
Sorry for the delay. I am still very new to .NET as well and have not done much with block references. I will look at this and help where I can but you should at least know that I'm not well versed in this language.
That said try using this in your object modified event. Then do the work in command ended event. I don't think you want to try opening the object that called the event.
If e.DBObject.Id.ObjectClass.Name = "AcDbAttribute" Then
End If
Then try this in your Command ended event.
For Each ObjID In IDList
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
Using trans As Transaction = db.TransactionManager.StartTransaction
Dim Myatt As AttributeReference = trans.GetObject(ObjID, OpenMode.ForRead, False)
MsgBox(Myatt.TextString)
End Using
Next
Private Sub callback_ObjectModified(ByVal sender As Object, ByVal e As ObjectEventArgs) Dim trans As Transaction = e.DBObject.Database.TransactionManager.StartTransaction Try Dim obj As Object = trans.GetObject(e.DBObject.Id, OpenMode.ForRead) If obj.GetType.Name.ToString = "BlockReference" Then If Not IDList.Contains(e.DBObject.Id) Then IDList.Add(e.DBObject.Id) Debug.Print(e.DBObject.Id.ToString) Debug.Print(sender.ToString) MsgBox(obj.GetType.Name.ToString) Dim myBlockRef As BlockReference = e.DBObject.Id.GetObject(OpenMode.ForRead) MsgBox(myBlockRef.ObjectId.ToString) Dim BTR As BlockTableRecord = myBlockRef.BlockTableRecord.GetObject(OpenMode.ForRead) MsgBox(BTR.Name) End If End If Catch ex As Exception End Try trans.Dispose() End Sub Private Sub callback_CommandEnded(ByVal sender As Object, ByVal e As CommandEventArgs) Dim myDwg As Document = DocumentManager.MdiActiveDocument Dim myDB As Database = ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database Try For Each objid In IDList Using myTrans As Transaction = myDwg.TransactionManager.StartTransaction Dim myTags As New ArrayList Dim myStrings As New ArrayList myTags.Add("FunctionText") myStrings.Add("This is a test") SetAttributes(objid, myTags, myStrings) myTrans.Commit() End Using Next IDList.Clear() Catch ex As Exception End Try RemoveHandler myDB.ObjectModified, AddressOf callback_ObjectModified RemoveHandler myDoc.CommandEnded, AddressOf callback_CommandEnded End Sub Public Sub SetAttributes(ByVal BlockID As ObjectId, ByVal TagList As ArrayList, ByVal StringList As ArrayList) Dim myTransMan As DatabaseServices.TransactionManager Dim myTrans As DatabaseServices.Transaction Dim myDwg As Document myDwg = Application.DocumentManager.MdiActiveDocument myTransMan = myDwg.TransactionManager myTrans = myTransMan.StartTransaction Dim myBlockRef As BlockReference Dim myAttColl As AttributeCollection myBlockRef = BlockID.GetObject(OpenMode.ForWrite, False) myAttColl = myBlockRef.AttributeCollection Dim myEnt As ObjectId Dim myAttRef As AttributeReference For Each myEnt In myAttColl myAttRef = myEnt.GetObject(OpenMode.ForWrite, False) If TagList.Contains(myAttRef.Tag) Then Dim X As Integer = TagList.BinarySearch(myAttRef.Tag) If X >= 0 Then myAttRef.TextString = StringList(X) End If End If Next myTrans.Commit() myTrans.Dispose() myTransMan.Dispose() End Sub
Seams like everthing works great until I try to open up the attref for read then I get an exception...any ideas
Dave,
Sorry I haven't looked at this much. I've been right out straight.
I see several potential problems I think but have not had time to test. It would be helpfult too if you could tell me what it is you're trying to accomplish. Please post any progress you've made and I'll try to look at it later next week.
Bill
