I'm using VB.NET to write a routine that autmatically calculates the area of the polyline nearest to a block (the pline surrounds the block) an then adds the area to the blocks attribute.
I managed to write the program to do this manually for a selected pline and block.
How can I automatically select a pline nearest to the selected blocks' insertion point?
Help is much appreciated..
thanks in advance!
You might be want instead to select block within the crossingpolygon method,
if you've added just one block within, see if this helps:
<CommandMethod("TUR")> _ Public Shared Sub testUpdateRooms() Dim blockname As String = "ROOM" ' chnage block name Dim tagname As String = "ROOMAREA" ' change tag Dim db As Database = HostApplicationServices.WorkingDatabase Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim ed As Editor = doc.Editor Dim filtpline As TypedValue() = New TypedValue(1) {New TypedValue(0, "lwpolyline"), New TypedValue(70, 1)} Dim pres As PromptSelectionResult = ed.SelectAll(New SelectionFilter(filtpline)) If pres.Status <> PromptStatus.OK Then Return End If Dim filtblock As TypedValue() = New TypedValue(1) {New TypedValue(0, "insert"), New TypedValue(2, blockname)} Using tr As Transaction = doc.TransactionManager.StartTransaction() For Each sobj As SelectedObject In pres.Value Dim ent As DBObject = tr.GetObject(sobj.ObjectId, OpenMode.ForRead, False) Dim pline As Polyline = TryCast(ent, Polyline) If pline Is Nothing Then Return End If Dim pts As New Point3dCollection() For n As Integer = 0 To pline.NumberOfVertices - 2 pts.Add(pline.GetPoint3dAt(n)) Next Dim res As PromptSelectionResult = ed.SelectCrossingPolygon(pts, New SelectionFilter(filtblock)) If res.Status <> PromptStatus.OK Then Continue For End If Dim sset As SelectionSet = res.Value If sset.Count = 0 Then Continue For End If ' if more than one block found, then make polyline to be cyan colored to select room with extrafluous blocks If sset.Count > 1 Then pline.UpgradeOpen() pline.ColorIndex = 121 Else Dim ids As ObjectId() = sset.GetObjectIds() Dim blkobj As DBObject = tr.GetObject(ids(0), OpenMode.ForRead, False) Dim bref As BlockReference = TryCast(blkobj, BlockReference) If bref Is Nothing Then Continue For End If Dim atts As AttributeCollection = bref.AttributeCollection For Each id As ObjectId In atts Dim attref As AttributeReference = DirectCast(tr.GetObject(id, OpenMode.ForRead, False), AttributeReference) If attref.Tag = tagname Then bref.UpgradeOpen() attref.UpgradeOpen() attref.TextString = Math.Round(pline.Area, 2).ToString() '' i.e. precision 2 decimals, or ' possible to use a field with pline area as well attref.DowngradeOpen() bref.DowngradeOpen() End If Next End If Next tr.Commit() End Using End Sub
It is a nice solution but it worked partly.
First, I changed SelectCrossingPolygon to SelectWindowPolygon because some blocks are bigger dan the room, so they overlap with another room.
Secondly Some plines contain arcs, so the the returned vertices not always create a polygone that is around the block.
Is there a way to also use of arcs in the pointselection to form the SelectWindowPolygon?
I think in this case you an to gather the points along the polyline route
with small steps between,then gather them all in the point3dcollection
to perform the window selection
tnx for your help!
Do you think it's possible to make a selection for just the insertion point of the block?
The size of the attributes changes with the different text lengths.
That makes it difficult to select just one block, because the text overlaps more then one pline...
Wouter
