.NET
Can't access BlockReference in database
3 REPLIES 3
stardust1611
599 Views, 3 Replies
Hi. I inserted a block from a dwg drawing with the following method:
public static ObjectId InsertBlock(string fileName, Point3d insPoint)
            var acadDoc = Application.DocumentManager.MdiActiveDocument;
            var blockId = default(ObjectId);
            using (var acadLockDoc = acadDoc.LockDocument())
                var dbTemp = new Database(false, true);
                dbTemp.ReadDwgFile(fileName, FileShare.Read, false, "");
                var blockName = Path.GetFileNameWithoutExtension(fileName);
                SymbolUtilityServices.ValidateSymbolName(blockName, false);
                var acadDb = acadDoc.Database;
                blockId = acadDb.Insert(blockName, dbTemp, false);
                var blockToInsert = new BlockReference(insPoint, blockId);
                using (Transaction acadTrans = acadDoc.TransactionManager.StartTransaction())
                    var blockTable = (BlockTable)acadTrans.GetObject(acadDoc.Database.BlockTableId, OpenMode.ForRead);
                    var activeSpace = (BlockTableRecord)acadTrans.GetObject(_db.CurrentSpaceId, OpenMode.ForWrite);
                    activeSpace.AppendEntity(blockToInsert);
                    acadTrans.AddNewlyCreatedDBObject(blockToInsert,true);
                    var block = (BlockTableRecord)acadTrans.GetObject(blockId, OpenMode.ForWrite);
                    foreach (ObjectId elementId in block)
                        var element = acadTrans.GetObject(elementId, OpenMode.ForRead);
                        if (element.GetType().Name.Equals("AttributeDefinition"))
                            var attDef = (AttributeDefinition)acadTrans.GetObject(elementId, OpenMode.ForRead);
                            var attRef = new AttributeReference();
                            attRef.SetAttributeFromBlock(attDef, blockToInsert.BlockTransform);
                            blockToInsert.AttributeCollection.AppendAttribute(attRef);
                            acadTrans.AddNewlyCreatedDBObject(attRef, true);
                    acadTrans.Commit();
            Application.UpdateScreen();
            return blockId;
After inserting a block, i can access it's BlockTableRecord like this:
var block = (BlockTableRecord)trans.GetObject(blockRefId, OpenMode.ForWrite);
 but i can't access the BlockReference object like this:
 var blockRef = trans.GetObject(blockRefId, OpenMode.ForWrite) as BlockReference;
 It's a null. What is going on?
Tags (1)
3 REPLIES 3
misstyped the two codelines on the end?
You will get the blocktablerecord by this:
trans.GetObject(blockId, OpenMode.ForWrite)
and the blockreference with that code:
trans.GetObject(blockToInsert.ObjectID, OpenMode.ForWrite)
in both cases you have used the variable <blockrefid> which I could not find within your snippet.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thank you Alfred, this worked. You couldn't find blockrefid variable because I'm calling the above method from another method where I have this variable, which holds the ObjectId of the inserted block.
But I'm not clear about one thing in the above method. I actually found this method on the internet. Why do I have to insert the block twice? Once like this, before starting transaction:
, and once like this in the transaction:
This looks like doing one and the same thing twice. Is there something that is not needed there?
Haris
this line:
just defines the blockdefintion.
and that line:
creates the reference (the insert) in the current space (modelspace or paperspace)
HTH, - alfred -
Alfred NESWADBA
”Boost
