Find nearest polyline with block
wouter
wouter
I'm using VB.NET to write a routine that autmatically calculates the area of the polyline nearest to a block (the pline surrounds the block) an then adds the area to the blocks attribute.
I managed to write the program to do this manually for a selected pline and block.
How can I automatically select a pline nearest to the selected blocks' insertion point?
Help is much appreciated..
thanks in advance!
Hallex
You might be want instead to select block within the crossingpolygon method,
if you've added just one block within, see if this helps:
        <CommandMethod("TUR")> _
        Public Shared Sub testUpdateRooms()
            Dim blockname As String = "ROOM"
            ' chnage block name
            Dim tagname As String = "ROOMAREA"
            ' change tag
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim filtpline As TypedValue() = New TypedValue(1) {New TypedValue(0, "lwpolyline"), New TypedValue(70, 1)}
            Dim pres As PromptSelectionResult = ed.SelectAll(New SelectionFilter(filtpline))
            If pres.Status <> PromptStatus.OK Then
                Return
            Dim filtblock As TypedValue() = New TypedValue(1) {New TypedValue(0, "insert"), New TypedValue(2, blockname)}
            Using tr As Transaction = doc.TransactionManager.StartTransaction()
                For Each sobj As SelectedObject In pres.Value
                    Dim ent As DBObject = tr.GetObject(sobj.ObjectId, OpenMode.ForRead, False)
                    Dim pline As Polyline = TryCast(ent, Polyline)
                    If pline Is Nothing Then
                        Return
                    Dim pts As New Point3dCollection()
                    For n As Integer = 0 To pline.NumberOfVertices - 2
                        pts.Add(pline.GetPoint3dAt(n))
                    Next
                    Dim res As PromptSelectionResult = ed.SelectCrossingPolygon(pts, New SelectionFilter(filtblock))
                    If res.Status <> PromptStatus.OK Then
                        Continue For
                    Dim sset As SelectionSet = res.Value
                    If sset.Count = 0 Then
                        Continue For
                    ' if more than one block found, then make polyline to be cyan colored to select room with extrafluous blocks
                    If sset.Count > 1 Then
                        pline.UpgradeOpen()
                        pline.ColorIndex = 121
                    Else
                        Dim ids As ObjectId() = sset.GetObjectIds()
                        Dim blkobj As DBObject = tr.GetObject(ids(0), OpenMode.ForRead, False)
                        Dim bref As BlockReference = TryCast(blkobj, BlockReference)
                        If bref Is Nothing Then
                            Continue For
                        Dim atts As AttributeCollection = bref.AttributeCollection
                        For Each id As ObjectId In atts
                            Dim attref As AttributeReference = DirectCast(tr.GetObject(id, OpenMode.ForRead, False), AttributeReference)
                            If attref.Tag = tagname Then
                                bref.UpgradeOpen()
                                attref.UpgradeOpen()
                                attref.TextString = Math.Round(pline.Area, 2).ToString() '' i.e. precision 2 decimals, or
                                ' possible to use a field with pline area as well
                                attref.DowngradeOpen()
                                bref.DowngradeOpen()
                        Next
                Next
                tr.Commit()
            End Using
        End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
wouter
Tnx, I'm going to try it!
wouter
It is a nice solution but it worked partly.
First, I changed SelectCrossingPolygon to SelectWindowPolygon because some blocks are bigger dan the room, so they overlap with another room.
Secondly Some plines contain arcs, so the the returned vertices not always create a polygone that is around the block.
Is there a way to also use of arcs in the pointselection to form the SelectWindowPolygon?
Hallex
I think in this case you an to gather the points along the polyline route
with small steps between,then gather them all in the point3dcollection
to perform the  window selection
wouter
tnx for your help!
Do you think it's possible to make a selection for just the insertion point of the block?
The size of the attributes changes with the different text lengths.
That makes it difficult to select just one block, because the text overlaps more then one pline...
Wouter
