I am aware of regex and several other string methods, but have not seen a built in way of checking against multiple patterns allowing for asterisks.
Curious what others have come up with.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Try asteriks preceded by "`" character, kinda "`*mybad"
if string.StartWith("`*mybad") etc
I see, escape the *, good tip.
I will try that also with the contains method, thanks
Yes, 'Contains' method will be handy in this case,
Cheers 🙂
Exactly the same as (wcmatch ...) in AutoLisp and acutWcMatch/acutWcMatchEx in ObjectARX doing:
Autodesk.AutoCAD.Internal.Utils.WcMatch(string str, string pattern); Autodesk.AutoCAD.Internal.Utils.WcMatchEx(string str, string pattern, bool ignoreCase);
Facebook | Twitter | LinkedIn
great suggestion, I saw your same post on theswamp from a while back.
I am actually doing a non-acad project, so have to use regular .net, but still cool to have access to acad's routines.
Yes, but that's not the 'easiest' way
namespace System { public static class WcMatchExtensionMethods { public static bool Matches( this string str, string pattern, bool ignoreCase ) { return Autodesk.AutoCAD.Internal.Utils.WcMatchEx( str, pattern, ignoreCase ); } public static bool Matches( this string str, string pattern ) { return Autodesk.AutoCAD.Internal.Utils.WcMatchEx( str, pattern, true ); } } }
Honestly I have never really used Autolisp or Regex either.
This is only from 5 minutes a messing around since I thought it might be good to see what Regex was about. I only knew it had something to do with matching character in strings, but taking a quick look at WCMATCH and this article Converting Wildcards to Regexes this might be a start, but there are guys with AutoLisp and Regex experience around here and other forums that would much know a much better approach.
A little console program playing around
using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Text.RegularExpressions; namespace ConsoleApplication8 { class Program { static void Main(string[] args) { string poo = "I have no idea and I have spent 5 minutes on this and have no idea if it will work"; Console.WriteLine(poo.WCMATCH("*z"));/////////////////////->False Console.WriteLine(poo.WCMATCH("*al"));////////////////////->False Console.WriteLine(poo.WCMATCH("min???s"));////////////////->True Console.WriteLine(poo.WCMATCH("*z", "*al", "min???s"));///->True Console.WriteLine(poo.WCMATCH("*z", "*al", "*ha"));///->True Console.ReadLine(); } } public static class StringExtensions { public static bool WCMATCH(this string text, params string[] patterns) { foreach (string pat in patterns) { string reg = s_wildcardToRegex(pat); if (Regex.Match(text, reg).Success) { return true; } } return false; } ///////////source http://www.codeproject.com/Articles/11556/Converting-Wildcards-to-Regexes private static string s_wildcardToRegex(string pattern) { return Regex.Escape(pattern).Replace("\\*", ".*").Replace("\\?", "."); } } }
*********Edit**********
DiningPhilosopher slipped in while I was posting and prime of example of what I meant when I I said other guys would know much better than I would. Actually I never said that but typed it.
wow, thanks for all the responses.
Oh, Tony! Of course your version is beautiful and laconic. For this you have new kudos from me!
