.NET
430 Views, 1 Reply
image attach
I use the following code to attach an image. But when I look at xref-manager the code doesn't look if the image is alreday attached and if you attach the image twice, you have a second line test_1 that may not be there (see image attach). Can somenone help me to edit my code ?
 <CommandMethod("attimage")> _
        Public Sub attimage()
            attim("c:\test.jpg")
        End Sub
        Private Sub attim(ByVal filenaam As String)
            Dim myDWG As ApplicationServices.Document
            myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Using trans As Transaction = myDWG.TransactionManager.StartTransaction()
                Dim idPaper As ObjectId = SymbolUtilityServices.GetBlockPaperSpaceId(myDWG.Database)
                Dim ms As BlockTableRecord = TryCast(trans.GetObject(idPaper, OpenMode.ForWrite), BlockTableRecord)
                Dim imageDef As RasterImageDef
                If filenaam = Nothing Then imageDef = Nothing Else imageDef = AddImageDef(myDWG.Database, trans, filenaam)
                If imageDef <> Nothing Then
                    Dim image As New RasterImage()
                    image.ImageDefId = imageDef.ObjectId
                    Dim imageId As ObjectId = ms.AppendEntity(image)
                    If imageId.IsNull Then
                        Throw New Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.NullObjectId)
                    trans.AddNewlyCreatedDBObject(image, True)
                    RasterImage.EnableReactors(True)
                    image.AssociateRasterDef(imageDef)
                    Dim puntcol As New Geometry.Point3dCollection
                    puntcol.Add(New Geometry.Point3d(0, 100, 0))
                    puntcol.Add(New Geometry.Point3d(100, 100, 0))
                    puntcol.Add(New Geometry.Point3d(100, 0, 0))
                    puntcol.Add(New Geometry.Point3d(0, 0, 0))
                    image.Orientation = New CoordinateSystem3d(New Point3d(0, 0, 0), New Vector3d(100, 0, 0), New Vector3d(0, 100, 0))
                    Dim vers As New Geometry.Point2dCollection
                    Dim mat As Matrix3d
                    mat = image.PixelToModelTransform.Inverse()
                    Dim i As Integer
                    For i = 0 To puntcol.Count - 1
                        puntcol(i) = puntcol(i).TransformBy(mat)
                        vers.Add(puntcol(i).Convert2d(New Plane()))
                    Next i
                    image.ColorIndex = 253
                    image.SetClipBoundary(ClipBoundaryType.Poly, vers)
                    Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("IMAGEFRAME", Convert.ToInt16(0))
                    image.DisplayOptions = ImageDisplayOptions.ShowUnaligned
                    image.ImageTransparency = False
                    Dim ids As New ObjectIdCollection()
                    Dim dot As DrawOrderTable = DirectCast(trans.GetObject(ms.DrawOrderTableId, OpenMode.ForWrite), DrawOrderTable)
                    ids.Add(imageId)
                    dot.MoveToBottom(ids)
                trans.Commit()
            End Using
        End Sub
        Public Shared Function AddImageDef(ByVal db As Database, ByVal trans As Transaction, ByVal imageFilespec As String) As RasterImageDef
            If Not File.Exists(imageFilespec) Then
                Throw New FileNotFoundException(imageFilespec)
            Dim idImageDict As ObjectId = RasterImageDef.GetImageDictionary(db)
            If idImageDict.IsNull Then
                idImageDict = RasterImageDef.CreateImageDictionary(db)
                Throw New InvalidOperationException("failed to get or create image dictionary")
            Dim imageDictionary As DBDictionary = TryCast(trans.GetObject(idImageDict, OpenMode.ForRead), DBDictionary)
            If imageDictionary = Nothing Then
                Throw New InvalidOperationException("Failed to open image dictionary")
            Dim imageDef As New RasterImageDef()
            Try
                imageDef.SourceFileName = imageFilespec
                imageDef.Load()
                Dim name As [String] = RasterImageDef.SuggestName(imageDictionary, imageFilespec)
                imageDictionary.UpgradeOpen()
                Dim idEntry As ObjectId = imageDictionary.SetAt(name, imageDef)
                If idEntry.IsNull Then
                    Throw New InvalidOperationException("Failed to add image definition to image dictionary")
                trans.AddNewlyCreatedDBObject(imageDef, True)
                Return imageDef
            Catch
                imageDef.Dispose()
                Throw
            End Try
        End Function
1 REPLY 1
Alexander.Rivilis
Do I understand correctly, the question is that there is no duplication of RasterImageDef? If so you can change AddImageDef function such as:
    Public Shared Function AddImageDef(ByVal db As DatabaseByVal trans As TransactionByVal imageFilespec As StringAs RasterImageDef
      End If
      End If
      End If
      End If
      For Each en As DBDictionaryEntry In imageDictionary
        Dim imgDef As RasterImageDef = TryCast(trans.GetObject(en.Value, OpenMode.ForRead), RasterImageDef)
        If imgDef IsNot Nothing Then
          If imgDef.ActiveFileName = imageFilespec Or imgDef.SourceFileName = imageFilespec Then
            imgDef.UpgradeOpen()
            ' imgDef.Load()
            Return imgDef
          End If
        End If
      Next
      Try
        imageDef.Load()
        End If
        Return imageDef
      Catch
        imageDef.Dispose()
        Throw
      End Try
    End Function
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
