I just finished developing an plugin for Autocad 2014 using the managed .net api
It appears that the client also want to use this addin in Autocad Mechanical 2014, but when i run netload on my dll nothing happens and my command is not available. Some googling gave me the impression that autocad mechanical only has a COM and c++ api, is that correct? is there any way i can make my code work in autocad mechanical?
Hope someone can give me a quick answer here!
Regards
Henrik
Referring back to the initial confusion as to whether AutoCAD Mechanical has a .NET API:
If a product is an AutoCAD vertical, then you can take it as read that it will support the vanilla AutoCAD APIs. However, that doesn't mean there is support in a particular API for objects and features that are unique to that vertical. For example, ACA objects don't support DXF, so you shouldn't use AutoLISP to edit them. Same for some vertical specific objects and .NET.
And (as you have found) you should never assume that an AutoCAD vertical has the same search path/sysvar settings as vanilla AutoCAD.
