.NET
Problem removing CAD standards programatically (VB.NET)
6 REPLIES 6
btmsoftware
674 Views, 6 Replies
Hi there,
Here is the story.
I have a drawing with say 3 CAD standards associated.
Given the full file name (including path), I'm able to retreive the corresponding Xrecord and remove it from the dicstionary.
Then, if I open the configure Standards dialog, I only see the 2 standards left
so far so good.
The problems is that when I close the DWG, saving it of course, then reopen it and open the configure Standards dialog. They're all gone, including the 2 standards that should still be there.
I guess I do something wring but I have no idea what ????????
Here is my code:
Private Sub DetachStandard(_filename as String)
  Dim tr As Transaction = Nothing
  Dim db As Database = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database
  Dim sPath As String = ""
  Dim lock As Autodesk.AutoCAD.ApplicationServices.DocumentLock = Nothing
  Try
    ' 1st, we lock the database as we're going to modify it
    lock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument()
    ' We start the transaction
    tr = db.TransactionManager.StartTransaction
    ' Getting the database dictionary
    Dim nod As DBDictionary = tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForWrite, False)
    ' Getting AcStStandard in the dictionary. If none are present, it will be handled in the catch
    Dim id As ObjectId = nod.Item("AcStStandard")
    ' Getting standards dict
    Dim dict As DBDictionary = tr.GetObject(id, OpenMode.ForWrite, False)
    ' Looping thru standards list
    For Each entry As DictionaryEntry In dict
      sPath = ""
      Dim oId As ObjectId = entry.Value
      Dim record As Xrecord = tr.GetObject(oId, OpenMode.ForWrite, False)
      Dim arrData As Array = record.Data.AsArray
      Dim tValue As TypedValue = arrData(0)
      ' Getting the path of the DWS file
      If File.Exists(tValue.Value) Then
        sPath = tValue.Value.ToString
      Else
        Try
          sPath = HostApplicationServices.Current.FindFile(New FileInfo(tValue.Value.ToString).Name, db, FindFileHint.Default)
        Catch
        End Try
      If Not String.IsNullOrEmpty(sPath) Then
        ' Path has been resolved.
        If String.Compare(sPath, _filename, True) = 0 Then
          ' This is the one to remove
          record.Erase()
        Else
          ' This is not the one to remove, doing nothing
      Else
        ' Path not resolved. File not found, nothing to do
    Next
  Catch ex As System.Exception
    If String.Compare(ex.Message, "eKeyNotFound", True) = 0 Then
      ' No CAD standards in this file
      Return
    Throw ex
  Finally
    If Not lock Is Nothing Then lock.Dispose() 'Unlocking the database as we're done
    Try
      If Not tr Is Nothing Then
        tr.Commit() ' Commitin the transaction
    Catch
      ' Ignoring any error when commiting the transaction
    End Try
  End Try
End Sub
Any help would be greatly appreciated
Tags (1)
6 REPLIES 6
fieldguy
in reply to: btmsoftware
Have you tried moving the commit statement before you dispose the lock?
dgorsman
Are you certain that removing the XRecord is the *only* thing that happens when standards are removed properly?  There may be other references which are expecting it to be there (via handle or other reference), or an index tracker is expecting them to start at 0 and continue through 1, 2, 3, etc. and not 1, 2, 3 or 0, 2, 3.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
jeffHGCE
in reply to: dgorsman
btmsoftware
in reply to: fieldguy
@ Fieldguy
will try that and let you know
I doubt though since as long as I stay in the drawing, everything is fine, all the other standards are still here, it's only when I close it and re-open it.
@ Jeff
The blog show how to attach a standard (actually that is exactly the code I use to attach those standards), no to detach them
@Dgorsman
Maybe, but then the question is: What ? Where ? How do I get tid of it ?
btmsoftware
fieldguy,
Moved the transaction commit before unlocking the document and actually, the result is that ALL stamndards are detached immediateely so it's not better because I'm still detaching standards that shouldn't be detached
fieldguy
I realized that it probably would not solve your problem.  It *looks* like a logic error to me and I decided to mention it.  I am a big fan of "using" statements and the structure is always:
lock document
start transaction
commit transaction
unlock document
”Boost
