Balloons & Parts List
morrisangelo
Message 1 of 18
morrisangelo
Is there a way to keep the parts list open while ballooning so I can see which items still need to be ballooned?
Replies (17)
Message 2 of 18
Cadmanto
The short answer is "No".  But, you could take a screen shot of the part list edit with the snapping tool and cross off as you do the ballooning.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 18
mdavis22569
Here is an ilogic code that will tell you what needs to be ballooned still
Mike Davis
Message 4 of 18
mdavis22569
Format:HTML Format
Version:1.0
StartHTML: 165
EndHTML: 7872
StartFragment: 314
EndFragment: 7840
StartSelection: 314
EndSelection: 314
SyntaxEditor Code Snippet
Dim oDrawDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
Dim oPartsList As PartsList = oSheet.PartsLists.Item(1)
Dim s As String
Dim msg as String = ""
For Each oRow As PartsListRow In oPartsList.PartsListRows
If Not oRow.Ballooned Then
s = ""
For Each oCell As PartsListCell In oRow
s = s & oCell.Value & " "
Next
msg = msg & s & vbNewLine
End If
Next
'show results
MsgBox(msg)
Beep
Mike Davis
Message 5 of 18
morrisangelo
Michael, no ilogic file attached...
Spoke too soon....
Message 6 of 18
morrisangelo
I noticed that the Bill of Materials stays open independently, but not the Parts List...
Message 7 of 18
mdavis22569
This will give you the balloon number/Item number and name needed in a pop up box.
Mike Davis
Message 8 of 18
morrisangelo
Perfect. That works very well and I'll use it regularly.
Thanks, Michael.
On a side note, and without having to run a rule, it would be nice for Autodesk to program for allowing the parts list to stay open, and for each item that gets ballooned, the appropriate box in the parts list would add the balloon icon on that line on the fly...
Message 9 of 18
mdavis22569
Glad it will help ... I found it very helpful to just run the ilogic .. it's much faster than open and closing the parts list ...
The only thing they need to add is the parts list says open...
Mike Davis
Message 10 of 18
-niels-
I'm not sure if my post is going to be helpful or relevant, but here's my method of finding out if i've ballooned everything:
I right-click on an existing balloon, select "attach balloon from list" and in the dialog select "items not ballooned".
I normally use the "auto-baloon" function to attach balloons to any missing parts and use the method i described to check if there's anything i missed due to updates or changes.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 11 of 18
morrisangelo
Niels, that's another good way to find what's not ballooned, but I'd still like to have that list (or the rule from above) keep an open window on my 2nd screen while ballooning. How about it, Autodesk?
Thanks for the tip...I didn't even know that was there...
Message 12 of 18
johnsonshiue
Hi! This is a very interesting request. I would like to confirm with you that the main reason why you want to see PartsList dialog when ballooning is because there is no feedback from Inventor letting you know if the component has been ballooned. Is it true?
Thanks!
Software Test Engineer
Message 13 of 18
mdavis22569
That's why I have the illogic to tell me what instill needing a balloon
If I have a 50 different part assembly and I'm ballooning it.... It would be awesome to know have items still to balloon or what is still needing a balloon. Or an indicator that it's fully ballooned.
Mike Davis
Message 14 of 18
mdavis22569
I created an new Idea for this
Please give it kudos for Autodesk to look into it
http://forums.autodesk.com/t5/inventor-ideastation/idb-p/v1232/tab/most-recent
be nice if we could see it without having to open and close the Parts list everytime to know if you've ballooned everything.
Mike Davis
Message 15 of 18
morrisangelo
Johnson, thanks for replying to my issue.
Yes, that's my issue when ballooning. I have a machine with 200+ different parts on it, some duplicates & some unique. After I balloon all of the obvious and easy parts in the views I have on my drawing, there's always a handful at the end that I have to go back and forth with by opening and closing the parts list to see which items have the balloon icon there, and which ones don't.
It's very tedious, and a bit frustrating, when I have to go in and out of the parts list dialogue to see what items remained "unballooned".
Michael's ilogic rule, as well as niels suggestion are both good alternatives, but a floating parts list while you're ballooning would be great, especially if it would add the balloon symbols in the parts list column as you balloon your items.
Message 16 of 18
mdavis22569
Post on the idea's link ... the more positive we get the more they look into it ...
Mike Davis
Message 17 of 18
morrisangelo
Done Michael! Thanks for setting up that request over there.
I think this is potentially a great productivity tool that, in my opinion, should be added to Inventor's basic functionality. Can't think of a reason not to do this.
Message 18 of 18
-niels-
Voted and commented this as well.
Here's a direct link to the idea, the link Michael posted took me to the "most recent" page.
http://forums.autodesk.com/t5/inventor-ideastation/a-way-to-know-if-everything-is-ballooned/idi-p/56...
Niels van der Veer
The Netherlands
