This has probably been asked plenty of times, and I see there is an ongoing case with Autodesk.
But does anyone have a way of adding the line above the symbols correctly??
Currently I just use a double underscore, but the distances does not get correct according to the parameters set in the standard.
My dream is that there will come a toggle on/off gagdet (or drop-down menu) in the surface symbol pop-up menu 👍
Br,
Frank
Solved by Yijiang.Cai. Go to Solution.
Hi
You can submit your idea and describe your expectations in detail on Idea Station.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Kacper Suchomski
@fichri17 I suppose it is the similar idea with https://forums.autodesk.com/t5/inventor-ideas/support-for-iso-21920-surface-symbols/idi-p/11226625. If true, could you please vote the idea here?
We are working on the idea, and please join the Inventor Alpha/Beta via clicking on https://autode.sk/InventorBeta. More details, please access https://forums.autodesk.com/t5/inventor-forum/inventor-feedback-beta-project-how-do-i-get-access/td-...
Many thanks!
That is correct, the issue is as the other idea case.
Glad to hear you are working on the issue.
I have joined the beta/alpha so will be glad to contribute 👍
Br,
Frank
