This is the log file /tmp/Adlm.log it is created when Maya 2012 fails to launch and gives me License status [5.2.2]
887 2011/08/08 13:01:41 Reason=Fatal error887 2011/08/08 13:01:41 ComputerName= mbp
887 2011/08/08 13:01:41 OS= Mac OS X 10.6.8 (10K549)
887 2011/08/08 13:01:41 File=AdlmIntSATSLicense.cpp,Line=1492887 2011/08/08 13:01:41 AdlmIntError=37 [Error loading FLEXnet activation spec from trusted storage]887 2011/08/08 13:01:49 Reason=Fatal error887 2011/08/08 13:01:49 ComputerName= mbp
887 2011/08/08 13:01:49 OS= Mac OS X 10.6.8 (10K549)
887 2011/08/08 13:01:49 File=AdlmIntSATSLicense.cpp,Line=1278887 2011/08/08 13:01:49 AdlmIntError=38 [Error getting license usage and behavior]4309 2011/08/08 20:49:59 Reason=License repair4309 2011/08/08 20:49:59 ComputerName= mbp
4309 2011/08/08 20:49:59 OS= Mac OS X 10.6.8 (10K549)
4309 2011/08/08 20:49:59 ShortCode=UELWY9R6ETRHDAZGQ1V27XL5Y48F3K7Z4309 2011/08/08 20:49:59 LicenseStatus=5.2.24309 2011/08/08 20:49:59 ExpirationDate=2011/08/154309 2011/08/08 20:49:59 Usage=N/A4309 2011/08/08 20:49:59 Behavior=N/A
Could you please explain why Maya fails to launch?
Please uninstall Maya
delete following files manually
/Library/Application Support/Autodesk/Adlm/.config/*.pit/Library/Preferences/FLEXnet Publisher/FLEXnet/adskflex_00691b00_tsf.data/Library/Preferences/FLEXnet Publisher/FLEXnet/adskflex_00691b00_tsf.data_backup.001
Install Maya, it should fix the license issue.
It doesn't fix the issue and you didn't answer my question, which was:
License is corrupt or license related files are corrupt.
can you post the latest log
and license.env file from Maya program folder
What I posted is the log file. The license.env is
MAYA_LICENSE=Unlimited
MAYA_LICENSE_METHOD=Standalone
is it the log the same after deletion of the files and reinstall ?
You know as well as i do that the /tmp directory is erased after a reboot, so there is no new Adlm.log anymore. I think you're trying to answer a question I did not ask. I'm not interested in how to repair the license. I know how to do that. Your recommendation is incorrect. This is the 5th or so time my licenses break. It's incredibly annoying. I always end up needing to reactivate manually. But that was not the point of my question.
I would like you (Autodesk) is to tell me why it is that Maya stops working, based on the information that is provided in the log file.
You said that the reason was "License is corrupt or license related files are corrupt."
That's awfully vague. It does not tell me what caused that to happen, nor does it tell me what I can do to prevent it from happening again. So, let me try to be more precise. When I wrote "why Maya fails" I want to know; can you tell from the log file what caused the corruption and which file got corruptued, so that I can take measures to prevent reoccurrence.
Sorry, I got the question wrong.
there are many reasons for corruption.
in the past certain SATA drives caused issues, this is not case with newer drivers/software
if you have bootcamp, it might cause similar issues.
or any software which tampers with anchor record (special sectors on the hard disk) would case similar issue.
http://www.thnkr.com/wiki/index.php?title=License_status_5.2.2
does this happen after a software crash
can you make sure your software is up to date (maya and macosx)
You may not have realized who I am when you quoted that article. Look again. This time look a little closer. See? Recognize my name there? Awesome. I'm impressed.
Yes, crashing Maya breaks licenses. The licenses do not break everytime it crashes, there are certain conditions that need to be met. But this is reproducible. Even a "Force Quit" can, under the right circumstances break a license.
Can I make sure my software id up to date? Maya 2012 is up to date. I can't run an up-to-date OS because you haven't certified 10.7 . Also, installing 10.7 involves repartitioning the drive, which is precisely the kind of thing that according to Autodesk's own FAQ is one of those things that break AdLM. http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=3970195 See under point 9.
Did you already open a case for this with Autodesk ?
Via my reseller, yes. Let's just say this is a long-term project. For a while now, I have tried to demonstrate to you (Autodesk) that AdLM is deeply flawed, and that you (Autodesk) are unable to provide answers to the simplest questions regarding code that you (Autodesk) developed yourself. Autodesk has refused to acknowledge that there is even so much as a problem at all. For the most part, it's been blamed on me, for "pushing the limits". Well...
So far, I have received from you (Autodesk) a number of improbable "solutions", including, I kid you not, not backing up my hard drive. None of the proposed solutions work. But I have still not received an answer to a fairly simple question:
What causes this and how do I stop this from happening?
I think I'm entitled to an answer to that question. I'm sure you feel the same way.
I would suggest that once you (Autodesk) have confirmed the crashes as the cause and assuming that you (Autodesk) agree that crashing an application ought not break the license (that's a pretty straightforward requirement), you (Autodesk) fix the bug.
Until then, we seem to agree that AdLM stops working for no discernable reason and that Autodesk cannot recommend anything hat will remedy the situation.
I understand your frustration, I will open a case for you and have some deal with directly. this doesnt seem to be common issue as I could only find 2 instances on google search, both are related your issue.
I will check the internal cases you opened and will have someone work with you. I am really sorry it took longer for a permenant solution.
When it comes to the technology behind the licensin it is not completely Autodesk developed one. we are implementing a 3rd party solutions used by many other software vendors.
This is not stated as excuse, but just clarfiy the point.
Unless a community member has similar situation, we will not continue posting this thread untill we find a solution working directly with you.
Thank you for your cooperation.
I still have not received a meaningful answer. Not here, not from support, not from QA, not from your developers. Who do I need to call to get you guys to DO something about this?
My colleague is working on finding an answer for you, as you can see this is not a common issue with any other customer, so we would need more time find the cause.
Since my colleague is communicating directly on this, we will keep this thread for the final solution.
I'm underwhelmed. Quote: "We are waiting for a response from the developers." That has been going on for over a month now.
Despite reassurances that "This is an active topic within the development team in order to determine cause and a path forward." I still have not received a solution or even so much as an answer to my questions,
It should come as no surprise then, that despite the fact that an Autodesk representative contacted me to "get something set up", a solution is still not available. I was also contacted on twitter by your "Global Web Support Content Manager" who recommended I consult THIS forum. I'm afraid he didn't quite appreciate just how useless that recommendation was.
