Installation & Licensing
Error assigning serial number to product.
5 REPLIES 5
855 Views, 5 Replies
I'm having a problem with my AutoCAD activation, I am simply unable to activate my product since my license code is not valid, and when I looked what was wrong I saw this:
Error assigning serial number to product: This is an operation implementation generated fault
So if you could help me I would appreciate it thanks.
Thank you for your time.
Sincerely yours Dean Babic
5 REPLIES 5
domagoj.krivosic
I am getting the same error. What can I do to fix it?
philip.s
Hi Dean,
This is typically an Education Community account issue where the only workaround is to create a new account using a different email address. Please let us know if you continue to experience issues and we'll gladly troubleshoot accordingly!
ivan.gretic
Hi, I'm experiencing the same problem, i says ''Error assigning serial number to product: This is an operation implementation generated fault'', and the serial number listed is not valid... Thank you for your help.
jggerth1
in reply to: ivan.gretic
Two possibilities come to mind.... one is that the authorization process is havig problems on autodesk's end of the internet.  The second is a bad serial number.  Presuming that you purchased this through a VAR, the best bet is to contact your reseller.  Thye are generally the first stop for initial installation support.
philip.s
in reply to: jggerth1
The "Error Assigning Serial Number to Product" error message is actually in regards to an Education Community account issue, where the only workaround at the moment is to create a new account using a different email address.
Administrator Productivity
