3ds Max stuck on "Autodesk LIcensing" window
Hello, I recently downloaded the student version of 3ds Max and installed it. The first time I ran it, I remember some kind of licensing window popping up that required me to fill out some information. However, after that, a blank popup titled "Autodesk Licensing" came up and 3ds Max did not load.
I have tried several things to fix this, including:
- Killing the 3dsmax.exe and LMP.exe processes and trying to start 3ds Max again
- Restarting my PC
- Reinstalling 3ds Max completely
- Repairing 3ds Max
- Redownloading 3ds Max through the Virtual Agent and reinstalling it
- Deleting the "adskflex_00691b00_tsf.data" and "adskflex_00691b00_tsf.data_backup.001" files from my C:/ProgramData/FLEXnet folder and restarting 3ds Max
Nothing has worked. The same window, "Autodesk Licensing", pops up every time.
If someone could help me out I'd really appreciate it - I need to use 3ds Max for class.
Otto
Hello kateryna.panchenko and welcome to the Autodesk community!
It looks like you're seeing a blank screen after downloading your software. This issue typically occurs because Internet Explorer is either blocking or cannot connect to Autodesk registration servers. Access to Autodesk services is blocked by either IE, network, or proxy server security settings. The following article(s) should help you resolve the problem:
Register Today (Product Activation Wizard) blank except for two radio buttons
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
TravisNave
What version of 3DS Max are you using and what is the OS of your computer?  Also, do you get a particular error?  Can you post the adlm log file in that same folder as your licenses?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Oh, sorry I forgot to post this, but the bot's solution worked. I uninstalled the IE 11 update and I think that did the trick. Thank you for your time though!
TravisNave
Thanks for the follow-up. I am sure it will help somebody else in the
future!
Autodesk Forums:
