DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Cursor lag in TruView 2022
3 REPLIES 3
dejan_cro
681 Views, 3 Replies
I've just installed TrueView 2022 and noticed that the cursor lags in model space. I can't find anything in options that would solve this.
I've found here https://forums.autodesk.com/t5/autocad-forum/cursor-lags/td-p/10189619 that in order to solve the same issue in AutoCad you shoud set GFXDX12 to 0 but I can't find a way to do this in TrueView.
3 REPLIES 3
pendean
in reply to: dejan_cro
Download and use the older DTV2021 or DTV2020 instead, the DTV2022 version added nothing but stress to weak computer systems.
Here is the link https://knowledge.autodesk.com/support/dwg-trueview/learn-explore/caas/sfdcarticles/sfdcarticles/Whe...
dejan_cro
Tried to install version 2021 now and there's no lag. Thanks for the tip!
I actually have quite a beefy system, so that was just really weird...
pendean
>>>...I actually have quite a beefy system...<<<
Apparently not where 2022 versions of AutoCAD/DTV are concerned: seems this variant has an innate ability to expose those underlying weaknesses.
