I've just installed TrueView 2022 and noticed that the cursor lags in model space. I can't find anything in options that would solve this.
I've found here https://forums.autodesk.com/t5/autocad-forum/cursor-lags/td-p/10189619 that in order to solve the same issue in AutoCad you shoud set GFXDX12 to 0 but I can't find a way to do this in TrueView.
Solved by dejan_cro. Go to Solution.
Solved by pendean. Go to Solution.
Tried to install version 2021 now and there's no lag. Thanks for the tip!
I actually have quite a beefy system, so that was just really weird...
