Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Multiple open drawings cannot drag and drop
4 REPLIES 4
272 Views, 4 Replies
I am trying to figure out how to copy an object or a drawing from one screen
to another. I have two AutoCad screens open side by side. Is there something
special you have to do to join the screens together to drag the object to
the other screen?
Sincerely,
Scott Graybill
4 REPLIES 4
Make sure you have no commands active in either drawing. Then select all of
the objects that you want to copy, press AND HOLD the RIGHT mouse button -
drag and release into the target drawing. That should do it.
Please do not email me privately with technical issues
Matt Dillon
Assistant Moderator: Autodesk Discussion Forums
http://www.dccadd.com
"Scott Graybill" wrote in message
news:2B57CD33016EC4365EB19069FBA01452@in.WebX.maYIadrTaRb...
screen
something
> the other screen?
> Sincerely,
> Scott Graybill
Also, make sure both drawings are saved before drag/drop.
May want to check Noun/Verb setting on the Selection Tab in the Options
menu, make it active.
Matt Dillon wrote in message
news:8B6AE83A5CDB70D13DB3A96878ADD39E@in.WebX.maYIadrTaRb...
of
> Matt Dillon
> screen
> something
to
> > the other screen?
> > Sincerely,
> > Scott Graybill
Another thing that you guys missed was that one has to right click on a grip
point of the selected objects, and then drag and drop to other drwg. You
should get the four menu options thereafter.
Rohit
John Herridge wrote in message
news:E08A6ADEB39D29243199B39D25D12D29@in.WebX.maYIadrTaRb...
> of
button -
> > Matt Dillon
> > screen
> > something
> to
> > > the other screen?
> > > Sincerely,
> > > Scott Graybill
This isn't something that I've had to do in the past. Active grips shouldn't
be a pre-requisite (and aren't on my system, anyway) for doing a right-click
drag-drop-copy.
Matt Dillon
"Rohit" wrote in message
news:1C4D7FCE338A9DF708D56F58FE1E1113@in.WebX.maYIadrTaRb...
grip
> Rohit
all
> > of
> button -
> > > Matt Dillon
one
> > > screen
> > > something
object
> > to
> > > > the other screen?
> > > > Sincerely,
> > > > Scott Graybill
