Yes, thanks.
"Siggi Pfundt, Autodesk" ha scritto nel
messaggio news:BEACC0E44B9C83C840EABA7EB3104692@in.WebX.maYIadrTaRb...
> Hi Michelangelo,
> please note the following :
> 1. the schedule tags react in general to the annotation plot size value
> which is defined in the drawing setup dialog / scale tab (Desktop >
Drawing
> Setup...).
> The annotation plot size itself is influenced by the custom scale value on
> the same tab and by the "size", which was used, when the tag was created
as
> design center symbol using _aeccreatecontentwizard.
> The block attributes in the Metric D A CH schedule tag files are created
> with a text height of 1
> This means in a METER drawing with the following dwgsetup settings on the
> scale tab and the conditions:
> - Drawing Scale is set to 1=1000 (1m = 1000 mm), > this effects that
> "Custom Scales" shows 1.
> - Annotation Plot Size is set to 0.25
> - the schedule tag has "Annotation Plot Size" checked in its content
> definition
> => the schedule tag is displayed with a attribute text height of 0.25 (m)
> This means also, if you are using other drawing units than METER, you have
> to set annotation plot size & Custom Scales properly to get a useful
height
> when inserting DC content files. But this is also valid in general for
> content files from other folder (Imperial / Metric), when you switch
between
> different drawing units.
> eg. for a MM drawing using Metric D A CH content:
> - Drawing unit MILLIMETER
> - Drawing Scale is set to 1=1 > this effects that "Custom Scales" shows
> 1.
> - Annotation Plot Size is set to 250
> Does this help ? I hope so.
> Siggi Pfundt [Autodesk]
> Michelangelo schrieb in im Newsbeitrag:
> 25837C35B14F8927E8957A4E69B1D3CE@in.WebX.maYIadrTaRb...
> > I'm trying to use some styles such Door Tags, Window Tags and so on
picked
> > from Metric D A CH directory of my italian version of ADT3, but they
don't
> > work as I would expected.
> > When I drag a symbol in the drawing and then select the object (a door,
a
> > window or an area) the Tag disappears... (!!).
> > Other Styles (such Metric or Imperial) work fine.
> > Any suggestion?
