I wouldn't pursue that too far. It won't work. 😞
I'd like to see more controls on endcap scaling (like "hold width", or "hold
length". But for now you can do like I do. I use set width studs. The only
wall styles that allow variable widths are those that don't use special
endcaps.
Please do not email me privately with technical issues
Matt Dillon
Assistant Moderator - Autodesk Discussion Forums
The D.C. CADD Company, Inc.
http://www.dccadd.com
Ron Dean wrote in message
<25E90DF43E2238F20E05F457D367BCDC@in.WebX.SaUCah8kaAW>...
>Thanks Matt, you found my problem.
>I am now able to get what I want for "Fixed width" walls and different
>endcap for each. Would be nice to get one that works for the "X" width stud
>walls, but no luck so far.
>Ron
>"Matt Dillon" wrote in message
>news:2751CEFF760DCE14BF9E3A1FE6EA4AFD@in.WebX.SaUCah8kaAW...
>> The "L" that goes the wrong way is most likely due to the polyline that
>> defines it being drawn clockwise. Redraw the polyline counterclockwise
and
>> redefine the endcap.
>> Matt Dillon
>> Assistant Moderator: Autodesk Discussion Forums
>> "Ron Dean" wrote in message
>> news:13AB05890F5CAE9906371511D3B77142@in.WebX.SaUCah8kaAW...
>> > I thought I understood how endcaps worked in ADT2 but in ADT3 I'm not
>> sure.
>> > I'm trying to create a better endcap for a stud wall that shows the
>gypsum
>> > board. The example in ADT3 shows a joint on one side of the wall as the
>> gyp
>> > bd goes around. Ok but not great solution.
>> > I know I've asked a similar question in the ADT2 NG a while back. At
the
>> > time I thought that Matt Dillion suggested that I use 2 "L" shaped
>pieces
>> > but that now only seems to work on one side and goes the wrong way on
>the
>> > other.
>> > Does anyone have a "clean" solution.
>> > Thanks,
>> > Ron
