I am trying to move a block on a curve with reference to 2 points on the curve.I am facing problem when one point is on horizontal part of curve and other point is at an angle.How do i place the block at angle.Please help.
Thanks in advance
You can obtain the angle from the first derivative of the curve at that point, and calculate the rotation angle from that angle.
Gaston Nunez
The first derivative of a curve is the slope or tangent in a point of a curve, the function/method GetFirstDerivative returns a vector3D with Dx,Dy,Dz components , if your curve is planar, there is no need for Dz, so the tangent=Dy/Dx then theta=math.atan2(Dy,Dx), another method is to calculate the angle from X axis to the derivative vector. GetFirstDerivative should be a method for every object that inherits from the curve class. Try the docs on this topic.
Gaston Nunez
I tried using the GetFirstDerivative method but i couldnt get direction.Can you please help me with sample code.
When you said "move block along...", did you mean you want user to drag a selected block/entity and when the mouse cursor is dragged, the block/entity moves along a given curve?
If so, one of my articles may be of help:
http://drive-cad-with-code.blogspot.ca/2012/03/moving-entity-along-curve.html
Norman Yuan
Hi Norman,
Thanks for the reply.Yes im moving block along a curve but im moving it with respect to 2 points.Im finding it difficult to get the direction.How do i get in which direction should i move.Any ideas??
