.NET
block on curve
6 REPLIES 6
411 Views, 6 Replies
block on curve
I am trying to move a block on a curve with reference to 2 points on the curve.I am facing problem when one point is on horizontal part of curve and other point is at an angle.How do i place the block at angle.Please help.
Thanks in advance
6 REPLIES 6
hgasty1001
You can obtain the angle from the first derivative of the curve at that point, and calculate the rotation angle from that angle.
Gaston Nunez
in reply to: hgasty1001
Thanks for the reply. Can you please help me with sample code.
Gulzar
hgasty1001
The first derivative of a curve is the slope or tangent in a point of a curve, the function/method GetFirstDerivative returns a vector3D with Dx,Dy,Dz components , if your curve is planar, there is no need for Dz, so the tangent=Dy/Dx then theta=math.atan2(Dy,Dx), another method is to calculate the angle from X axis to the derivative vector. GetFirstDerivative should be a method for every object that inherits from the curve class. Try the docs on this topic.
Gaston Nunez
I tried using the GetFirstDerivative method but i couldnt get direction.Can you please help me with sample code.
norman.yuan
When you said "move block along...", did you mean you want user to drag a selected block/entity and when the mouse cursor is dragged, the block/entity moves along a given curve?
If so, one of my articles may be of help:
http://drive-cad-with-code.blogspot.ca/2012/03/moving-entity-along-curve.html
Norman Yuan
Drive CAD With Code
in reply to: norman.yuan
Hi Norman,
Thanks for the reply.Yes im moving block along a curve but im moving it with respect to 2 points.Im finding it difficult to get the direction.How do i get in which direction should i move.Any ideas??
”Boost
