Inventor 2012 Installation Error 1935
Message 1 of 16
I've tried just about everything I could find on the internet for a solution to this and still no luck. (Including deleting temp, registry fix, updates, .NET Framework checking, and others).
Replies (15)
Message 2 of 16
alison.gangler
Please refer to the following post from the Windows Seven Forums regarding a similar issue when installing the Microsoft Visual C++ Redistributable package:
http://www.sevenforums.com/performance-maintenance/40511-set-registry-size-limit-unlimited-2.html
The posting indicates that the following steps will resolve the issue:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
Key: RegistrySizeLimit
Type: REG_DWORD
Value: 0xffffff (4294967295)
Reboot
As a Administrator open a Command Prompt and run "SFC /SCANNOW". The command should complete successfully and if any errors were found, they should be corrected.
It is always strongly recommended to fully back up the registry prior to making any modifications.
I hope this helps.
Cheers,
Alison
Alison Gangler
Install Engineer/PDG-AEC Product Group
Autodesk, Inc.
Message 3 of 16
Any chance you could give me some steps to perform this?
I did what I thought would be correct.
- Backed up the registry
- went to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
-created key RegistrySizeLimit
-set type to REG_DWORD
-set vaulue to 0xffffff (4294967295)
-performed clean boot
-attempted reinstall
xx Failed with the same error message at the same point
Message 4 of 16
Also, I checked for errors as you mentioned (forgot to include that in the last post)
Message 5 of 16
here is a screenshot of my attempt at a registry edit
Message 6 of 16
TravisNave
Just uninstall your Visual C++ and run the installer again.
Autodesk Forums:
Message 7 of 16
Travis, I removed Visual C++ as you stated then attempted a reinstall. No luck. So i removed more (because well... why not) after restarting and having attempted another isntall.
The only thing that changed was now Autodesk Design Review installed, but still no inventor.
Message 8 of 16
TravisNave
You have admin rights?  UAC off?  Antivirus disabled?  Media or download install?
Autodesk Forums:
Message 9 of 16
Admin Rights - check (even used install as admin during setup just to rule it out)
UAC - off
Microsoft Security Essentials - off
No other anti virus has ever been installed or used, I just freeze my C:
It's the download install - here is some log file. Thanks for your help as well
2012/2/28:16:59:06 Robert Hudson ROBERTHUDSON Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/2/28:16:59:06 Robert Hudson ROBERTHUDSON PageOpen ProductSelectionDialog2
2012/2/28:16:59:27 Robert Hudson ROBERTHUDSON PageOpen FullProgressDialog
2012/2/28:16:59:27 Robert Hudson ROBERTHUDSON Installing DirectX® Runtime: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/2/28:16:59:51 Robert Hudson ROBERTHUDSON Install DirectX® Runtime Succeeded
2012/2/28:16:59:51 Robert Hudson ROBERTHUDSON Installing Microsoft Windows Media Format 9.5 Series Runtime: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x64\wmf\95\wmfdist64.exe /quiet
2012/2/28:16:59:54 Robert Hudson ROBERTHUDSON Install Microsoft Windows Media Format 9.5 Series Runtime Failed Failure is ignored, Result=1603
2012/2/28:16:59:54 Robert Hudson ROBERTHUDSON Installing Autodesk® Inventor® 2012: TRANSFORMS="C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\x64\en-us\Inventor\inventor.mst;C:\Users\ROBERT~1\AppData\Local\Temp\_AI6C59.tmp\x64\inventor\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/28:17:05:33 Robert Hudson ROBERTHUDSON Install Autodesk® Inventor® 2012 Failed Installation aborted, Result=1603
2012/2/28:17:05:33 Robert Hudson ROBERTHUDSON Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Message 10 of 16
So looking at the logs, I actually paid attention and noticed that the error occured when installing file at path
which is microsoft windows media something or other 9.5? So i found that path, attempted a manual install, but i get error message "not enough storage is available to process this command" I assume this is where the real issue lies but again, I have no idea what to do /:
Message 11 of 16
TravisNave
What do you mean by "freezing your C:\" drive?
Autodesk Forums:
Message 12 of 16
its frozen under normal use so that once the computer boots, any changes that are made are destroyed after a restart.
I use a program called faronics deep freeze. I have uninstalled it for this, unsure if just disableing it was still causing a problem.
Message 13 of 16
after talking to some friends who work at Cisco. One by one I went and uninstalled windows security updates as they believed they were the root of all evil involving autodesk. After I uninstalled all the ones I was allowed to, no luck.
My solution? Well I own a Lenovo and they're awesome. 4 clicks and 1 hour later all my files were backed up, Windows was reset to factory default, files restored, and then I went on to successfully install Autodesk Inventor 2012. Today is a good day.
Thanks to everyone that read this thread and/or tried to help me solve the problem!
Message 14 of 16
robert_hudson    tengo el mismo problema estaria muy agradecido si me indicaras paso a paso como solucionastes tu problema de instalacion(error 1935)  ya que tambien tengo una lenovo estaria infinitamente agradecido
 robert_hudson    I have the same problem you would be very grateful if you indicate your problem of installation ( error 1935 ) since also I have a lenovo to me step by step like solucionastes you would be infinitely grateful
Message 15 of 16
amigo te lo agradeceria infinitamente como solucionastes el error 1935 que sale cuando estamos instalando
tengo el mismo problema que el tuyo estaria infinitamenteeeeeeeeeeee agradecido que dios te bendigue
Friend would thank it to you infinitely like solucionastes the error 1935 leaving when we are  installing
I have the same problem than yours infinitamenteeeeeeeeeeee would be grateful than god to you bendigue
Message 16 of 16
this solved my problem,thank you so much.
