Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Error 1603 and 1619 installing Autocad 2013
Hi, I'm trying to install Autocad 2013 but the installation program always terminate with error. Here is the log I get.
2013/2/27:15:43:45    TXEDES    TXEDES-HP    === Setup started on TXEDES-HP by TXEDES ===
2013/2/27:15:43:45    TXEDES    TXEDES-HP    Launch
2013/2/27:15:43:54    TXEDES    TXEDES-HP    PageOpen    LaunchDialog
2013/2/27:15:43:59    TXEDES    TXEDES-HP    PageOpen    LicenseDialog
2013/2/27:15:44:02    TXEDES    TXEDES-HP    PageOpen    ProductInfoDialog
2013/2/27:15:44:37    TXEDES    TXEDES-HP    PageOpen    ProductSelectionDialog2
2013/2/27:15:44:42    TXEDES    TXEDES-HP    PageOpen    FullProgressDialog
2013/2/27:15:44:43    TXEDES    TXEDES-HP    Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/2/27:15:48:48    TXEDES    TXEDES-HP    Install    .NET Framework Runtime 4.0    Succeeded
2013/2/27:15:48:48    TXEDES    TXEDES-HP    Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1034.exe /q
2013/2/27:15:49:40    TXEDES    TXEDES-HP    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
2013/2/27:15:49:40    TXEDES    TXEDES-HP    Rollback    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1619
TravisNave
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
.NET Framework Cleanup Tool solution didn't work for me, but the setup.ini procedure did.
Problem solved.
Thanks!
houda05
error 25001 my dowload was already finishing when a error msg tell me that some contnent are not correctly dowloading end i have to redownload the prorramme but i can't cause that take "15 hours" my connection is very slow , somoene can tell me please how i can repair the donwload or finish it correctly without missing all the recent dowload , a have google chrome end i can't find the button to redowload correctly or repair it . PS; sorry for the grammar or orthographe mistakes i try to do my best to explain ! & i coulden't found wheni can post my BUG
"2014/1/4:11:09:53 user USER-PC === Setup started on USER-PC by user ===
2014/1/4:11:09:53 user USER-PC Launch
2014/1/4:11:10:36 user USER-PC === Setup ended ===
2014/1/4:11:09:54 user USER-PC === Setup started on USER-PC by user ===
2014/1/4:11:09:54 user USER-PC Launch
2014/1/4:11:10:37 user USER-PC PageOpen LaunchDialog
2014/1/4:11:10:55 user USER-PC PageOpen LicenseDialog
2014/1/4:11:13:25 user USER-PC PageOpen ProductInfoDialog
2014/1/4:11:15:21 user USER-PC PageOpen ProductSelectionDialog2
2014/1/4:11:15:52 user USER-PC PageOpen FullProgressDialog
2014/1/4:11:15:53 user USER-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\AutoCAD_2012_French_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\user\AppData\Local\Temp\vcredist_x86_2010.log
2014/1/4:11:15:59 user USER-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2014/1/4:11:15:59 user USER-PC PageOpen InstallCompleteDialog
2014/1/4:11:17:23 user USER-PC === Setup ended ===
2014/1/4:11:18:05 user USER-PC === Setup started on USER-PC by user ===
2014/1/4:11:18:05 user USER-PC Launch
2014/1/4:11:18:12 user USER-PC === Setup ended ===
2014/1/4:11:18:06 user USER-PC === Setup started on USER-PC by user ===
2014/1/4:11:18:06 user USER-PC Launch
2014/1/4:11:18:12 user USER-PC PageOpen LaunchDialog
2014/1/4:11:18:20 user USER-PC PageOpen LicenseDialog
2014/1/4:11:18:20 user USER-PC PageOpen ProductSelectionDialog2
2014/1/4:11:18:24 user USER-PC PageOpen LicenseDialog
2014/1/4:11:18:24 user USER-PC PageOpen LaunchDialog
2014/1/4:11:18:33 user USER-PC PageOpen LicenseDialog
2014/1/4:11:18:47 user USER-PC PageOpen ProductInfoDialog
2014/1/4:11:19:52 user USER-PC PageOpen ProductSelectionDialog2
2014/1/4:11:20:13 user USER-PC PageOpen FullProgressDialog
2014/1/4:11:20:13 user USER-PC Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_French_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1036.exe /q
2014/1/4:11:21:40 user USER-PC Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/1/4:11:21:40 user USER-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_2012_French_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2014/1/4:11:22:21 user USER-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2014/1/4:11:22:21 user USER-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_French_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/1/4:11:23:10 user USER-PC Install DirectX Runtime Succeeded
2014/1/4:11:23:10 user USER-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:11:23:29 user USER-PC Install FaroSDK Succeeded
2014/1/4:11:23:29 user USER-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:11:24:13 user USER-PC Install Autodesk Material Library 2012 Succeeded
2014/1/4:11:24:13 user USER-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:11:24:57 user USER-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/1/4:11:24:57 user USER-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:11:25:17 user USER-PC Install Autodesk Content Service Succeeded
2014/1/4:11:25:18 user USER-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_French_Win_64bit\x64\fr-fr\acad\acad.mst;C:\Users\user\AppData\Local\Temp\_AIF594.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - French\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:11:29:40 user USER-PC Install AutoCAD® 2012 Succeeded
2014/1/4:11:29:42 user USER-PC Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AIF594.tmp\_la91CA.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - French\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:11:31:23 user USER-PC Install AutoCAD® 2012 Language Pack Failed Installation aborted, Result=1603
2014/1/4:11:32:17 user USER-PC Rollback AutoCAD® 2012 Succeeded
2014/1/4:11:32:34 user USER-PC Rollback Autodesk Content Service Succeeded
2014/1/4:11:33:08 user USER-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/1/4:11:33:30 user USER-PC Rollback Autodesk Material Library 2012 Succeeded
2014/1/4:11:33:38 user USER-PC Rollback FaroSDK Succeeded
2014/1/4:11:33:38 user USER-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/1/4:11:33:38 user USER-PC Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
2014/1/4:11:33:39 user USER-PC PageOpen InstallCompleteDialog
2014/1/4:11:33:46 user USER-PC === Setup ended ===
2014/1/4:11:45:20 user USER-PC === Setup started on USER-PC by user ===
2014/1/4:11:45:20 user USER-PC Launch
2014/1/4:11:46:04 user USER-PC === Setup ended ===
2014/1/4:11:46:04 user USER-PC PageOpen LaunchDialog
2014/1/4:11:46:19 user USER-PC PageOpen LicenseDialog
2014/1/4:12:10:44 user USER-PC PageOpen ProductInfoDialog
2014/1/4:12:11:10 user USER-PC PageOpen ProductSelectionDialog2
2014/1/4:12:11:31 user USER-PC PageOpen FullProgressDialog
2014/1/4:12:11:32 user USER-PC Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_French_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1036.exe /q
2014/1/4:12:13:14 user USER-PC Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/1/4:12:13:14 user USER-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_French_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/1/4:12:13:52 user USER-PC Install DirectX Runtime Succeeded
2014/1/4:12:13:52 user USER-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:12:14:11 user USER-PC Install FaroSDK Succeeded
2014/1/4:12:14:11 user USER-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:12:14:51 user USER-PC Install Autodesk Material Library 2012 Succeeded
2014/1/4:12:14:51 user USER-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:12:15:24 user USER-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/1/4:12:15:24 user USER-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:12:15:45 user USER-PC Install Autodesk Content Service Succeeded
2014/1/4:12:15:46 user USER-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_French_Win_64bit\x64\fr-fr\acad\acad.mst;C:\Users\user\AppData\Local\Temp\_AIE6E5.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - French\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:12:19:11 user USER-PC Install AutoCAD® 2012 Succeeded
2014/1/4:12:19:12 user USER-PC Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AIE6E5.tmp\_laE595.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_French_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - French\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/4:12:30:33 user USER-PC Install AutoCAD® 2012 Language Pack Failed Installation aborted, Result=1603
2014/1/4:12:31:23 user USER-PC Rollback AutoCAD® 2012 Succeeded
2014/1/4:12:31:38 user USER-PC Rollback Autodesk Content Service Succeeded
2014/1/4:12:32:19 user USER-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/1/4:12:32:41 user USER-PC Rollback Autodesk Material Library 2012 Succeeded
2014/1/4:12:32:48 user USER-PC Rollback FaroSDK Succeeded
2014/1/4:12:32:49 user USER-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/1/4:12:32:49 user USER-PC Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619"
I am trying to install Autocad 2013 in my windows 7 64bit pc. But not working the log file is given by.
i have tried to install .Net Framework but its not working. Help me out
when i installing autocad 2012 on my win8, failed! anyone can help?
2014/10/28:14:29:41 User K551LN === Setup started on K551LN by User ===
2014/10/28:14:29:41 User K551LN Launch
2014/10/28:14:30:36 User K551LN === Setup ended ===
2014/10/28:14:29:51 User K551LN === Setup started on K551LN by User ===
2014/10/28:14:29:51 User K551LN Launch
2014/10/28:14:30:37 User K551LN PageOpen LaunchDialog
2014/10/28:14:38:53 User K551LN PageOpen LicenseDialog
2014/10/28:14:43:58 User K551LN PageOpen ProductInfoDialog
2014/10/28:15:13:32 User K551LN === Setup ended ===
2014/10/28:20:20:10 User K551LN === Setup started on K551LN by User ===
2014/10/28:20:20:10 User K551LN Launch
2014/10/28:20:20:56 User K551LN === Setup ended ===
2014/10/28:20:20:20 User K551LN === Setup started on K551LN by User ===
2014/10/28:20:20:20 User K551LN Launch
2014/10/28:20:20:57 User K551LN PageOpen LaunchDialog
2014/10/28:20:21:12 User K551LN PageOpen LicenseDialog
2014/10/28:20:21:28 User K551LN PageOpen ProductInfoDialog
2014/10/28:20:21:52 User K551LN PageOpen ProductSelectionDialog2
2014/10/28:20:22:03 User K551LN PageOpen FullProgressDialog
2014/10/28:20:22:03 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/10/28:20:22:04 User K551LN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2014/10/28:20:22:07 User K551LN PageOpen InstallCompleteDialog
2014/10/28:20:22:23 User K551LN === Setup ended ===
2014/10/28:20:22:51 User K551LN === Setup started on K551LN by User ===
2014/10/28:20:22:51 User K551LN Launch
2014/10/28:20:23:01 User K551LN === Setup ended ===
2014/10/28:20:22:55 User K551LN === Setup started on K551LN by User ===
2014/10/28:20:22:55 User K551LN Launch
2014/10/28:20:23:01 User K551LN PageOpen LaunchDialog
2014/10/28:20:23:14 User K551LN === Setup ended ===
2014/10/28:20:24:02 User K551LN === Setup started on K551LN by User ===
2014/10/28:20:24:02 User K551LN Launch
2014/10/28:20:24:12 User K551LN === Setup ended ===
2014/10/28:20:24:06 User K551LN === Setup started on K551LN by User ===
2014/10/28:20:24:06 User K551LN Launch
2014/10/28:20:24:12 User K551LN PageOpen LaunchDialog
2014/10/28:20:24:33 User K551LN PageOpen LicenseDialog
2014/10/28:20:25:05 User K551LN PageOpen ProductInfoDialog
2014/10/28:20:25:22 User K551LN PageOpen ProductSelectionDialog2
2014/10/28:20:25:26 User K551LN PageOpen FullProgressDialog
2014/10/28:20:25:26 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/10/28:20:25:26 User K551LN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2014/10/28:20:25:27 User K551LN PageOpen InstallCompleteDialog
2014/10/28:20:35:22 User K551LN === Setup ended ===
2014/10/28:20:35:34 User K551LN === Setup started on K551LN by User ===
2014/10/28:20:35:34 User K551LN Launch
2014/10/28:20:35:34 User K551LN An instance of setup is already running. Only one instance of setup can run at a time.2014/10/28:20:35:36 User K551LN === Setup ended ===
2014/10/28:20:42:01 User K551LN === Setup started on K551LN by User ===
2014/10/28:20:42:01 User K551LN Launch
2014/10/28:20:42:01 User K551LN An instance of setup is already running. Only one instance of setup can run at a time.2014/10/28:20:42:10 User K551LN === Setup ended ===
2014/10/28:20:35:00 User K551LN === Setup started on K551LN by User ===
2014/10/28:20:35:00 User K551LN Launch
2014/10/28:20:35:00 User K551LN An instance of setup is already running. Only one instance of setup can run at a time.2014/10/28:20:42:14 User K551LN === Setup ended ===
2014/10/28:20:45:09 User K551LN === Setup started on K551LN by User ===
2014/10/28:20:45:09 User K551LN Launch
2014/10/28:20:46:04 User K551LN === Setup ended ===
2014/10/28:20:45:20 User K551LN === Setup started on K551LN by User ===
2014/10/28:20:45:20 User K551LN Launch
2014/10/28:20:46:05 User K551LN PageOpen LaunchDialog
2014/10/28:20:46:38 User K551LN PageOpen LicenseDialog
2014/10/28:20:46:43 User K551LN PageOpen ProductInfoDialog
2014/10/28:20:48:24 User K551LN PageOpen ProductSelectionDialog2
2014/10/28:20:48:27 User K551LN PageOpen FullProgressDialog
2014/10/28:20:48:27 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/10/28:20:48:39 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/10/28:20:48:39 User K551LN Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2014/10/28:20:48:54 User K551LN Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/10/28:20:48:54 User K551LN Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): E:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2014/10/28:20:49:05 User K551LN Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2014/10/28:20:49:05 User K551LN Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2014/10/28:20:50:37 User K551LN Install DirectX Runtime Succeeded
2014/10/28:20:50:37 User K551LN Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:20:50:53 User K551LN Install FaroSDK Succeeded
2014/10/28:20:50:53 User K551LN Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI3D9B.tmp\Media.mst"
2014/10/28:20:52:05 User K551LN Install Autodesk Material Library 2012 Succeeded
2014/10/28:20:52:07 User K551LN Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI3D9B.tmp\Media.mst"
2014/10/28:20:53:33 User K551LN Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/10/28:20:53:33 User K551LN Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\User\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/10/28:20:54:13 User K551LN Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/10/28:20:54:13 User K551LN Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:20:54:44 User K551LN Install Autodesk Content Service Succeeded
2014/10/28:20:54:45 User K551LN Installing AutoCAD® 2012: TRANSFORMS="E:\x64\en-us\acad\acad.mst;C:\Users\User\AppData\Local\Temp\_AI3D9B.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:20:55:52 User K551LN Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2014/10/28:20:56:03 User K551LN Rollback Autodesk Content Service Succeeded
2014/10/28:20:56:04 User K551LN Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/10/28:20:56:46 User K551LN Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/10/28:20:57:35 User K551LN Rollback Autodesk Material Library 2012 Succeeded
2014/10/28:20:57:39 User K551LN Rollback FaroSDK Succeeded
2014/10/28:20:57:39 User K551LN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/28:20:57:39 User K551LN Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
2014/10/28:20:57:44 User K551LN PageOpen InstallCompleteDialog
2014/10/28:20:58:17 User K551LN === Setup ended ===
2014/10/28:21:02:53 User K551LN === Setup started on K551LN by User ===
2014/10/28:21:02:53 User K551LN Launch
2014/10/28:21:03:03 User K551LN === Setup ended ===
2014/10/28:21:02:57 User K551LN === Setup started on K551LN by User ===
2014/10/28:21:02:57 User K551LN Launch
2014/10/28:21:03:03 User K551LN PageOpen LaunchDialog
2014/10/28:21:03:23 User K551LN PageOpen LicenseDialog
2014/10/28:21:03:48 User K551LN PageOpen ProductInfoDialog
2014/10/28:21:04:22 User K551LN PageOpen ProductSelectionDialog2
2014/10/28:21:04:24 User K551LN PageOpen FullProgressDialog
2014/10/28:21:04:24 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/10/28:21:04:37 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/10/28:21:04:37 User K551LN Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2014/10/28:21:04:51 User K551LN Install DirectX Runtime Succeeded
2014/10/28:21:04:51 User K551LN Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:21:05:03 User K551LN Install FaroSDK Succeeded
2014/10/28:21:05:04 User K551LN Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI7A78.tmp\Media.mst"
2014/10/28:21:05:47 User K551LN Install Autodesk Material Library 2012 Succeeded
2014/10/28:21:05:47 User K551LN Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI7A78.tmp\Media.mst"
2014/10/28:21:06:44 User K551LN Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/10/28:21:06:44 User K551LN Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:21:07:01 User K551LN Install Autodesk Content Service Succeeded
2014/10/28:21:07:01 User K551LN Installing AutoCAD® 2012: TRANSFORMS="E:\x64\en-us\acad\acad.mst;C:\Users\User\AppData\Local\Temp\_AI7A78.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:21:08:00 User K551LN Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2014/10/28:21:08:10 User K551LN Rollback Autodesk Content Service Succeeded
2014/10/28:21:08:51 User K551LN Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/10/28:21:09:39 User K551LN Rollback Autodesk Material Library 2012 Succeeded
2014/10/28:21:09:43 User K551LN Rollback FaroSDK Succeeded
2014/10/28:21:09:44 User K551LN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/28:21:09:44 User K551LN Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
2014/10/28:21:09:44 User K551LN PageOpen InstallCompleteDialog
2014/10/28:21:13:05 User K551LN === Setup ended ===
2014/10/28:21:15:38 User K551LN === Setup started on K551LN by User ===
2014/10/28:21:15:38 User K551LN Launch
2014/10/28:21:16:30 User K551LN === Setup ended ===
2014/10/28:21:15:50 User K551LN === Setup started on K551LN by User ===
2014/10/28:21:15:50 User K551LN Launch
2014/10/28:21:16:32 User K551LN PageOpen LaunchDialog
2014/10/28:21:16:49 User K551LN PageOpen LicenseDialog
2014/10/28:21:16:49 User K551LN PageOpen ProductSelectionDialog2
2014/10/28:21:16:54 User K551LN PageOpen LicenseDialog
2014/10/28:21:16:54 User K551LN PageOpen LaunchDialog
2014/10/28:21:17:06 User K551LN PageOpen LicenseDialog
2014/10/28:21:17:31 User K551LN PageOpen ProductInfoDialog
2014/10/28:21:17:45 User K551LN PageOpen ProductSelectionDialog2
2014/10/28:21:17:50 User K551LN PageOpen FullProgressDialog
2014/10/28:21:17:50 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/10/28:21:18:02 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/10/28:21:18:02 User K551LN Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2014/10/28:21:18:33 User K551LN Install DirectX Runtime Succeeded
2014/10/28:21:18:33 User K551LN Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:21:18:48 User K551LN Install FaroSDK Succeeded
2014/10/28:21:18:48 User K551LN Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AICA11.tmp\Media.mst"
2014/10/28:21:19:51 User K551LN Install Autodesk Material Library 2012 Succeeded
2014/10/28:21:19:51 User K551LN Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AICA11.tmp\Media.mst"
2014/10/28:21:21:05 User K551LN Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/10/28:21:21:05 User K551LN Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:21:21:22 User K551LN Install Autodesk Content Service Succeeded
2014/10/28:21:21:22 User K551LN Installing AutoCAD® 2012: TRANSFORMS="E:\x64\en-us\acad\acad.mst;C:\Users\User\AppData\Local\Temp\_AICA11.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:21:22:39 User K551LN Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2014/10/28:21:22:50 User K551LN Rollback Autodesk Content Service Succeeded
2014/10/28:21:23:30 User K551LN Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/10/28:21:24:16 User K551LN Rollback Autodesk Material Library 2012 Succeeded
2014/10/28:21:24:20 User K551LN Rollback FaroSDK Succeeded
2014/10/28:21:24:20 User K551LN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/28:21:24:21 User K551LN Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
2014/10/28:21:24:25 User K551LN PageOpen InstallCompleteDialog
2014/10/28:21:24:45 User K551LN === Setup ended ===
2014/10/28:21:25:17 User K551LN === Setup started on K551LN by User ===
2014/10/28:21:25:17 User K551LN Launch
2014/10/28:21:25:27 User K551LN === Setup ended ===
2014/10/28:21:25:21 User K551LN === Setup started on K551LN by User ===
2014/10/28:21:25:21 User K551LN Launch
2014/10/28:21:25:27 User K551LN PageOpen LaunchDialog
2014/10/28:21:25:51 User K551LN PageOpen LicenseDialog
2014/10/28:21:26:14 User K551LN PageOpen ProductInfoDialog
2014/10/28:21:26:26 User K551LN PageOpen ProductSelectionDialog2
2014/10/28:21:26:30 User K551LN PageOpen FullProgressDialog
2014/10/28:21:26:30 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/10/28:21:26:43 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/10/28:21:26:43 User K551LN Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2014/10/28:21:26:56 User K551LN Install DirectX Runtime Succeeded
2014/10/28:21:26:56 User K551LN Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:21:27:06 User K551LN Install FaroSDK Succeeded
2014/10/28:21:27:06 User K551LN Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIA102.tmp\Media.mst"
2014/10/28:21:27:46 User K551LN Install Autodesk Material Library 2012 Succeeded
2014/10/28:21:27:47 User K551LN Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIA102.tmp\Media.mst"
2014/10/28:21:28:37 User K551LN Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/10/28:21:28:37 User K551LN Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:21:28:54 User K551LN Install Autodesk Content Service Succeeded
2014/10/28:21:28:54 User K551LN Installing AutoCAD® 2012: TRANSFORMS="E:\x64\en-us\acad\acad.mst;C:\Users\User\AppData\Local\Temp\_AIA102.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/28:21:36:31 User K551LN Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2014/10/28:21:36:41 User K551LN Rollback Autodesk Content Service Succeeded
2014/10/28:21:37:22 User K551LN Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/10/28:21:38:11 User K551LN Rollback Autodesk Material Library 2012 Succeeded
2014/10/28:21:38:14 User K551LN Rollback FaroSDK Succeeded
2014/10/28:21:38:14 User K551LN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/28:21:38:14 User K551LN Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
2014/10/28:21:38:14 User K551LN PageOpen InstallCompleteDialog
2014/10/28:21:39:00 User K551LN === Setup ended ===
2014/10/28:21:40:45 User K551LN === Setup started on K551LN by User ===
2014/10/28:21:40:45 User K551LN Launch
2014/10/28:21:41:36 User K551LN === Setup ended ===
2014/10/28:21:40:58 User K551LN === Setup started on K551LN by User ===
2014/10/28:21:40:58 User K551LN Launch
2014/10/28:21:41:37 User K551LN PageOpen LaunchDialog
2014/10/28:21:41:59 User K551LN PageOpen LicenseDialog
2014/10/28:21:42:04 User K551LN PageOpen ProductInfoDialog
2014/10/28:21:42:16 User K551LN PageOpen ProductSelectionDialog2
2014/10/28:21:42:18 User K551LN PageOpen FullProgressDialog
2014/10/28:21:42:18 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/10/28:21:42:19 User K551LN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2014/10/28:21:42:21 User K551LN PageOpen InstallCompleteDialog
2014/10/28:21:42:57 User K551LN === Setup ended ===
2014/11/4:09:56:54 User K551LN === Setup started on K551LN by User ===
2014/11/4:09:56:54 User K551LN Launch
2014/11/4:09:57:11 User K551LN === Setup ended ===
2014/11/4:09:56:55 User K551LN === Setup started on K551LN by User ===
2014/11/4:09:56:55 User K551LN Launch
2014/11/4:09:57:05 User K551LN PageOpen LaunchDialog
2014/11/4:09:58:40 User K551LN PageOpen LicenseDialog
2014/11/4:09:59:52 User K551LN PageOpen ProductInfoDialog
2014/11/4:10:05:13 User K551LN PageOpen ProductSelectionDialog2
2014/11/4:10:05:18 User K551LN PageOpen FullProgressDialog
2014/11/4:10:05:18 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/11/4:10:05:29 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/11/4:10:05:29 User K551LN Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/11/4:10:06:47 User K551LN Install DirectX Runtime Succeeded
2014/11/4:10:06:47 User K551LN Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/4:10:07:05 User K551LN Install FaroSDK Succeeded
2014/11/4:10:07:05 User K551LN Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/4:10:07:50 User K551LN Install Autodesk Material Library 2012 Succeeded
2014/11/4:10:07:50 User K551LN Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/4:10:09:19 User K551LN Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/11/4:10:09:19 User K551LN Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\User\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/4:10:09:47 User K551LN Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/11/4:10:09:47 User K551LN Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/4:10:10:09 User K551LN Install Autodesk Content Service Succeeded
2014/11/4:10:10:10 User K551LN Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\User\AppData\Local\Temp\_AID9FF.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/4:10:15:46 User K551LN Install AutoCAD® 2012 Succeeded
2014/11/4:10:15:48 User K551LN Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AID9FF.tmp\_la2496.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/4:10:20:10 User K551LN Install AutoCAD® 2012 Language Pack Succeeded
2014/11/4:10:20:11 User K551LN Installing Autodesk® Inventor® Fusion 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\InventorFusion\InventorFusion.mst;C:\Users\User\AppData\Local\Temp\_AID9FF.tmp\x64\InventorFusion\InventorFusion-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/4:10:24:22 User K551LN Install Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/4:10:24:23 User K551LN Installing Autodesk Inventor Fusion Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AID9FF.tmp\_la2F0.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/4:10:24:41 User K551LN Install Autodesk Inventor Fusion Language Pack Succeeded
2014/11/4:10:24:42 User K551LN Installing Autodesk Inventor Fusion plug-in for AutoCAD 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\AcFusion\AcFusion.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/4:10:24:45 User K551LN Install Autodesk Inventor Fusion plug-in for AutoCAD 2012 Succeeded
2014/11/4:10:24:45 User K551LN Installing Inventor Fusion plug-in for AutoCAD 2012 Language Pack: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/4:10:24:50 User K551LN Install Inventor Fusion plug-in for AutoCAD 2012 Language Pack Succeeded
2014/11/4:10:24:51 User K551LN PageOpen InstallCompleteDialog
2014/11/4:10:24:59 User K551LN === Setup ended ===
2014/11/4:12:54:27 User K551LN === Setup started on K551LN by User ===
2014/11/4:12:54:27 User K551LN Launch
2014/11/4:12:54:38 User K551LN === Setup ended ===
2014/11/4:12:54:29 User K551LN === Setup started on K551LN by User ===
2014/11/4:12:54:29 User K551LN Launch
2014/11/4:12:54:33 User K551LN PageOpen MaintenanceDialog
2014/11/4:12:54:36 User K551LN PageOpen MaintVerifyReadyDialog
2014/11/4:12:54:38 User K551LN PageOpen FullProgressDialog
2014/11/4:12:54:38 User K551LN Installing AutoCAD® 2012: REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/4:12:59:20 User K551LN Reinstall/uninstall AutoCAD® 2012 ({5783F2D7-A001-0409-1102-0060B0CE6BBA}) Succeeded
2014/11/4:12:59:20 User K551LN Uninstall AutoCAD® 2012 Succeeded
2014/11/4:12:59:20 User K551LN PageOpen MaintCompleteDialog
2014/11/4:12:59:23 User K551LN === Setup ended ===
2014/11/4:13:42:39 User K551LN === Setup started on K551LN by User ===
2014/11/4:13:42:39 User K551LN Launch
2014/11/4:13:42:51 User K551LN === Setup ended ===
2014/11/4:13:42:42 User K551LN === Setup started on K551LN by User ===
2014/11/4:13:42:42 User K551LN Launch
2014/11/4:13:42:52 User K551LN PageOpen LaunchDialog
2014/11/4:13:43:13 User K551LN PageOpen LicenseDialog
2014/11/4:13:43:27 User K551LN PageOpen ProductInfoDialog
2014/11/4:13:59:47 User K551LN === Setup ended ===
2014/11/5:15:41:53 User K551LN === Setup started on K551LN by User ===
2014/11/5:15:41:53 User K551LN Launch
2014/11/5:15:42:00 User K551LN === Setup ended ===
2014/11/5:15:41:54 User K551LN === Setup started on K551LN by User ===
2014/11/5:15:41:54 User K551LN Launch
2014/11/5:15:42:02 User K551LN PageOpen LaunchDialog
2014/11/5:15:42:17 User K551LN PageOpen LicenseDialog
2014/11/5:15:42:21 User K551LN PageOpen ProductInfoDialog
2014/11/5:15:42:41 User K551LN PageOpen ProductSelectionDialog2
2014/11/5:15:42:44 User K551LN PageOpen FullProgressDialog
2014/11/5:15:42:44 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/11/5:15:42:53 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/11/5:15:42:53 User K551LN Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/11/5:15:44:08 User K551LN Install DirectX Runtime Succeeded
2014/11/5:15:44:08 User K551LN Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:15:45:05 User K551LN Install Autodesk Material Library 2012 Succeeded
2014/11/5:15:45:05 User K551LN Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:15:45:55 User K551LN Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/11/5:15:45:55 User K551LN Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:15:46:25 User K551LN Install Autodesk Content Service Succeeded
2014/11/5:15:46:31 User K551LN Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\User\AppData\Local\Temp\_AIC8D8.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:15:52:12 User K551LN Install AutoCAD® 2012 Succeeded
2014/11/5:15:52:16 User K551LN Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIC8D8.tmp\_la3CDA.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:15:56:19 User K551LN Install AutoCAD® 2012 Language Pack Succeeded
2014/11/5:15:56:19 User K551LN Installing Autodesk® Inventor® Fusion 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\InventorFusion\InventorFusion.mst;C:\Users\User\AppData\Local\Temp\_AIC8D8.tmp\x64\InventorFusion\InventorFusion-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:15:59:03 User K551LN Install Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/5:15:59:04 User K551LN Installing Autodesk Inventor Fusion Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIC8D8.tmp\_la8080.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:15:59:04 User K551LN Install Autodesk Inventor Fusion Language Pack Failed Installation aborted, Result=1624
2014/11/5:15:59:51 User K551LN Rollback Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/5:16:00:39 User K551LN Rollback AutoCAD® 2012 Language Pack Succeeded
2014/11/5:16:02:35 User K551LN Rollback AutoCAD® 2012 Succeeded
2014/11/5:16:02:52 User K551LN Rollback Autodesk Content Service Succeeded
2014/11/5:16:03:55 User K551LN Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/11/5:16:04:44 User K551LN Rollback Autodesk Material Library 2012 Succeeded
2014/11/5:16:04:44 User K551LN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/11/5:16:04:44 User K551LN Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
2014/11/5:16:04:45 User K551LN PageOpen InstallCompleteDialog
2014/11/5:16:04:47 User K551LN === Setup ended ===
2014/11/5:16:11:58 User K551LN === Setup started on K551LN by User ===
2014/11/5:16:11:58 User K551LN Launch
2014/11/5:16:12:07 User K551LN === Setup ended ===
2014/11/5:16:44:20 User K551LN === Setup started on K551LN by User ===
2014/11/5:16:44:20 User K551LN Launch
2014/11/5:16:44:31 User K551LN === Setup ended ===
2014/11/5:16:44:21 User K551LN === Setup started on K551LN by User ===
2014/11/5:16:44:21 User K551LN Launch
2014/11/5:16:44:32 User K551LN PageOpen LaunchDialog
2014/11/5:17:19:37 User K551LN PageOpen LicenseDialog
2014/11/5:17:21:35 User K551LN PageOpen ProductInfoDialog
2014/11/5:17:22:01 User K551LN PageOpen ProductSelectionDialog2
2014/11/5:17:22:04 User K551LN PageOpen FullProgressDialog
2014/11/5:17:22:04 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/11/5:17:22:11 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/11/5:17:22:11 User K551LN Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/11/5:17:22:26 User K551LN Install DirectX Runtime Succeeded
2014/11/5:17:22:26 User K551LN Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:22:54 User K551LN Install Autodesk Material Library 2012 Succeeded
2014/11/5:17:22:54 User K551LN Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:23:26 User K551LN Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/11/5:17:23:26 User K551LN Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:23:45 User K551LN Install Autodesk Content Service Succeeded
2014/11/5:17:23:49 User K551LN Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\User\AppData\Local\Temp\_AIEAD1.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:28:42 User K551LN Install AutoCAD® 2012 Succeeded
2014/11/5:17:28:43 User K551LN Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIEAD1.tmp\_la8B4B.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:31:21 User K551LN Install AutoCAD® 2012 Language Pack Succeeded
2014/11/5:17:31:21 User K551LN Installing Autodesk® Inventor® Fusion 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\InventorFusion\InventorFusion.mst;C:\Users\User\AppData\Local\Temp\_AIEAD1.tmp\x64\InventorFusion\InventorFusion-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:33:51 User K551LN Install Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/5:17:33:51 User K551LN Installing Autodesk Inventor Fusion Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIEAD1.tmp\_la413B.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:33:52 User K551LN Install Autodesk Inventor Fusion Language Pack Failed Installation aborted, Result=1624
2014/11/5:17:34:22 User K551LN Rollback Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/5:17:34:53 User K551LN Rollback AutoCAD® 2012 Language Pack Succeeded
2014/11/5:17:36:07 User K551LN Rollback AutoCAD® 2012 Succeeded
2014/11/5:17:36:18 User K551LN Rollback Autodesk Content Service Succeeded
2014/11/5:17:37:09 User K551LN Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2014/11/5:17:37:35 User K551LN Rollback Autodesk Material Library 2012 Succeeded
2014/11/5:17:37:36 User K551LN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/11/5:17:37:36 User K551LN Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
2014/11/5:17:37:36 User K551LN PageOpen InstallCompleteDialog
2014/11/5:17:38:04 User K551LN === Setup ended ===
2014/11/5:17:38:54 User K551LN === Setup started on K551LN by User ===
2014/11/5:17:38:54 User K551LN Launch
2014/11/5:17:39:01 User K551LN === Setup ended ===
2014/11/5:17:38:59 User K551LN PageOpen LaunchDialog
2014/11/5:17:39:11 User K551LN PageOpen LicenseDialog
2014/11/5:17:40:01 User K551LN PageOpen ProductInfoDialog
2014/11/5:17:40:49 User K551LN PageOpen ProductSelectionDialog2
2014/11/5:17:40:51 User K551LN PageOpen FullProgressDialog
2014/11/5:17:40:51 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/11/5:17:40:59 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/11/5:17:40:59 User K551LN Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/11/5:17:41:10 User K551LN Install DirectX Runtime Succeeded
2014/11/5:17:41:10 User K551LN Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:41:32 User K551LN Install Autodesk Material Library 2012 Succeeded
2014/11/5:17:41:32 User K551LN Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:42:11 User K551LN Install Autodesk Material Library 2012 - Low Resolution Succeeded
2014/11/5:17:42:11 User K551LN PageOpen InstallCompleteDialog
2014/11/5:17:42:19 User K551LN === Setup ended ===
2014/11/5:17:48:05 User K551LN === Setup started on K551LN by User ===
2014/11/5:17:48:05 User K551LN Launch
2014/11/5:17:48:13 User K551LN === Setup ended ===
2014/11/5:17:48:06 User K551LN === Setup started on K551LN by User ===
2014/11/5:17:48:06 User K551LN Launch
2014/11/5:17:48:12 User K551LN PageOpen LaunchDialog
2014/11/5:17:48:25 User K551LN PageOpen LicenseDialog
2014/11/5:17:48:30 User K551LN PageOpen ProductInfoDialog
2014/11/5:17:49:08 User K551LN PageOpen ProductSelectionDialog2
2014/11/5:17:49:13 User K551LN PageOpen FullProgressDialog
2014/11/5:17:49:13 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/11/5:17:49:20 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/11/5:17:49:20 User K551LN Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/11/5:17:49:33 User K551LN Install DirectX Runtime Succeeded
2014/11/5:17:49:33 User K551LN Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:49:46 User K551LN Install FaroSDK Succeeded
2014/11/5:17:49:46 User K551LN Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:49:55 User K551LN Install Autodesk Content Service Succeeded
2014/11/5:17:49:57 User K551LN Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\User\AppData\Local\Temp\_AI4B56.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:53:20 User K551LN Install AutoCAD® 2012 Succeeded
2014/11/5:17:53:21 User K551LN Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI4B56.tmp\_la1751.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:56:48 User K551LN Install AutoCAD® 2012 Language Pack Succeeded
2014/11/5:17:56:49 User K551LN Installing Autodesk® Inventor® Fusion 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\InventorFusion\InventorFusion.mst;C:\Users\User\AppData\Local\Temp\_AI4B56.tmp\x64\InventorFusion\InventorFusion-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:59:19 User K551LN Install Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/5:17:59:19 User K551LN Installing Autodesk Inventor Fusion Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI4B56.tmp\_la9257.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:17:59:19 User K551LN Install Autodesk Inventor Fusion Language Pack Failed Installation aborted, Result=1624
2014/11/5:17:59:47 User K551LN Rollback Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/5:18:00:17 User K551LN Rollback AutoCAD® 2012 Language Pack Succeeded
2014/11/5:18:01:37 User K551LN Rollback AutoCAD® 2012 Succeeded
2014/11/5:18:01:47 User K551LN Rollback Autodesk Content Service Succeeded
2014/11/5:18:01:51 User K551LN Rollback FaroSDK Succeeded
2014/11/5:18:01:51 User K551LN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/11/5:18:01:52 User K551LN Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
2014/11/5:18:01:52 User K551LN PageOpen InstallCompleteDialog
2014/11/5:18:02:09 User K551LN === Setup ended ===
2014/11/5:18:03:58 User K551LN === Setup started on K551LN by User ===
2014/11/5:18:03:58 User K551LN Launch
2014/11/5:18:04:10 User K551LN === Setup ended ===
2014/11/5:18:03:59 User K551LN === Setup started on K551LN by User ===
2014/11/5:18:03:59 User K551LN Launch
2014/11/5:18:04:06 User K551LN PageOpen LaunchDialog
2014/11/5:18:04:18 User K551LN PageOpen LicenseDialog
2014/11/5:18:04:21 User K551LN PageOpen ProductInfoDialog
2014/11/5:18:04:30 User K551LN PageOpen ProductSelectionDialog2
2014/11/5:18:04:33 User K551LN PageOpen FullProgressDialog
2014/11/5:18:04:34 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/11/5:18:04:41 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/11/5:18:04:41 User K551LN Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/11/5:18:04:52 User K551LN Install DirectX Runtime Succeeded
2014/11/5:18:04:52 User K551LN Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:18:05:03 User K551LN Install FaroSDK Succeeded
2014/11/5:18:05:03 User K551LN Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:18:05:14 User K551LN Install Autodesk Content Service Succeeded
2014/11/5:18:05:14 User K551LN Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\User\AppData\Local\Temp\_AID62D.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:18:09:25 User K551LN Install AutoCAD® 2012 Succeeded
2014/11/5:18:09:26 User K551LN Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AID62D.tmp\_laD31B.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:18:13:11 User K551LN Install AutoCAD® 2012 Language Pack Succeeded
2014/11/5:18:13:12 User K551LN Installing Autodesk® Inventor® Fusion 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\InventorFusion\InventorFusion.mst;C:\Users\User\AppData\Local\Temp\_AID62D.tmp\x64\InventorFusion\InventorFusion-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:18:17:08 User K551LN Install Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/5:18:17:08 User K551LN Installing Autodesk Inventor Fusion Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AID62D.tmp\_laE0F6.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/5:18:17:08 User K551LN Install Autodesk Inventor Fusion Language Pack Failed Installation aborted, Result=1624
2014/11/5:18:18:01 User K551LN Rollback Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/5:18:18:56 User K551LN Rollback AutoCAD® 2012 Language Pack Succeeded
2014/11/5:18:20:53 User K551LN Rollback AutoCAD® 2012 Succeeded
2014/11/5:18:21:09 User K551LN Rollback Autodesk Content Service Succeeded
2014/11/5:18:21:14 User K551LN Rollback FaroSDK Succeeded
2014/11/5:18:21:14 User K551LN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/11/5:18:21:14 User K551LN Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
2014/11/5:18:21:15 User K551LN PageOpen InstallCompleteDialog
2014/11/5:18:24:48 User K551LN === Setup ended ===
2014/11/7:09:06:57 User K551LN === Setup started on K551LN by User ===
2014/11/7:09:06:57 User K551LN Launch
2014/11/7:09:07:12 User K551LN === Setup ended ===
2014/11/7:09:06:58 User K551LN === Setup started on K551LN by User ===
2014/11/7:09:06:58 User K551LN Launch
2014/11/7:09:07:11 User K551LN PageOpen LaunchDialog
2014/11/7:09:07:39 User K551LN PageOpen LicenseDialog
2014/11/7:09:07:44 User K551LN PageOpen ProductInfoDialog
2014/11/7:09:08:00 User K551LN PageOpen ProductSelectionDialog2
2014/11/7:09:08:03 User K551LN PageOpen FullProgressDialog
2014/11/7:09:08:03 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/11/7:09:08:13 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/11/7:09:08:13 User K551LN Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/11/7:09:09:40 User K551LN Install DirectX Runtime Succeeded
2014/11/7:09:09:40 User K551LN Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:09:10:05 User K551LN Install FaroSDK Succeeded
2014/11/7:09:10:05 User K551LN Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:09:10:23 User K551LN Install Autodesk Content Service Succeeded
2014/11/7:09:10:24 User K551LN Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\User\AppData\Local\Temp\_AI1141.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:09:17:31 User K551LN Install AutoCAD® 2012 Succeeded
2014/11/7:09:17:34 User K551LN Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI1141.tmp\_laBF9B.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:09:22:22 User K551LN Install AutoCAD® 2012 Language Pack Succeeded
2014/11/7:09:22:22 User K551LN Installing Autodesk® Inventor® Fusion 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\InventorFusion\InventorFusion.mst;C:\Users\User\AppData\Local\Temp\_AI1141.tmp\x64\InventorFusion\InventorFusion-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:09:25:34 User K551LN Install Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/7:09:25:34 User K551LN Installing Autodesk Inventor Fusion Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI1141.tmp\_la1D7A.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:09:25:35 User K551LN Install Autodesk Inventor Fusion Language Pack Failed Installation aborted, Result=1624
2014/11/7:09:26:01 User K551LN Rollback Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/7:09:26:39 User K551LN Rollback AutoCAD® 2012 Language Pack Succeeded
2014/11/7:09:28:56 User K551LN Rollback AutoCAD® 2012 Succeeded
2014/11/7:09:29:17 User K551LN Rollback Autodesk Content Service Succeeded
2014/11/7:09:29:23 User K551LN Rollback FaroSDK Succeeded
2014/11/7:09:29:23 User K551LN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/11/7:09:29:23 User K551LN Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
2014/11/7:09:29:24 User K551LN PageOpen InstallCompleteDialog
2014/11/7:09:30:18 User K551LN === Setup ended ===
2014/11/7:12:22:46 User K551LN === Setup started on K551LN by User ===
2014/11/7:12:22:46 User K551LN Launch
2014/11/7:12:23:05 User K551LN === Setup ended ===
2014/11/7:15:14:49 User K551LN === Setup started on K551LN by User ===
2014/11/7:15:14:49 User K551LN Launch
2014/11/7:15:15:01 User K551LN === Setup ended ===
2014/11/7:15:14:50 User K551LN === Setup started on K551LN by User ===
2014/11/7:15:14:50 User K551LN Launch
2014/11/7:15:15:01 User K551LN PageOpen MaintenanceDialog
2014/11/7:15:15:06 User K551LN PageOpen RepairDialog
2014/11/7:15:15:10 User K551LN PageOpen MaintVerifyReadyDialog
2014/11/7:15:15:10 User K551LN PageOpen FullProgressDialog
2014/11/7:15:15:10 User K551LN Installing AutoCAD® 2012: ADSK_LAUNCH_MODE="STANDALONE" ADSK_RUNNING_FROM_ADMIN="FALSE" REINSTALL="ALL" REINSTALLMODE="eum" REMOVE="" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:15:22:13 User K551LN Reinstall AutoCAD® 2012 Succeeded
2014/11/7:15:22:14 User K551LN PageOpen MaintCompleteDialog
2014/11/7:15:22:30 User K551LN === Setup ended ===
2014/11/7:15:28:33 User K551LN === Setup started on K551LN by User ===
2014/11/7:15:28:33 User K551LN Launch
2014/11/7:15:28:49 User K551LN === Setup ended ===
2014/11/7:15:28:34 User K551LN === Setup started on K551LN by User ===
2014/11/7:15:28:34 User K551LN Launch
2014/11/7:15:28:50 User K551LN PageOpen MaintenanceDialog
2014/11/7:15:28:52 User K551LN PageOpen MaintVerifyReadyDialog
2014/11/7:15:28:54 User K551LN PageOpen FullProgressDialog
2014/11/7:15:28:54 User K551LN Installing AutoCAD® 2012: REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:15:29:32 User K551LN Uninstall AutoCAD® 2012 Failed Installation aborted, Result=1602
2014/11/7:15:29:32 User K551LN PageOpen MaintFailedDialog
2014/11/7:15:29:41 User K551LN === Setup ended ===
2014/11/7:15:30:21 User K551LN === Setup started on K551LN by User ===
2014/11/7:15:30:21 User K551LN Launch
2014/11/7:15:30:37 User K551LN === Setup ended ===
2014/11/7:15:39:29 User K551LN === Setup started on K551LN by User ===
2014/11/7:15:39:29 User K551LN Launch
2014/11/7:15:39:39 User K551LN === Setup ended ===
2014/11/7:15:40:07 User K551LN === Setup started on K551LN by User ===
2014/11/7:15:40:07 User K551LN Launch
2014/11/7:15:40:07 User K551LN An instance of setup is already running. Only one instance of setup can run at a time.2014/11/7:15:40:10 User K551LN === Setup ended ===
2014/11/7:15:39:30 User K551LN === Setup started on K551LN by User ===
2014/11/7:15:39:30 User K551LN Launch
2014/11/7:15:39:33 User K551LN PageOpen LaunchDialog
2014/11/7:15:39:36 User K551LN PageOpen LicenseDialog
2014/11/7:15:39:38 User K551LN PageOpen ProductInfoDialog
2014/11/7:15:39:41 User K551LN PageOpen ProductSelectionDialog2
2014/11/7:15:40:14 User K551LN === Setup ended ===
2014/11/7:15:42:23 User K551LN === Setup started on K551LN by User ===
2014/11/7:15:42:23 User K551LN Launch
2014/11/7:15:42:38 User K551LN === Setup ended ===
2014/11/7:15:42:24 User K551LN === Setup started on K551LN by User ===
2014/11/7:15:42:24 User K551LN Launch
2014/11/7:15:42:38 User K551LN PageOpen MaintenanceDialog
2014/11/7:15:42:41 User K551LN PageOpen MaintVerifyReadyDialog
2014/11/7:15:42:43 User K551LN PageOpen FullProgressDialog
2014/11/7:15:42:43 User K551LN Installing AutoCAD® 2012: REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:15:45:01 User K551LN Uninstall AutoCAD® 2012 Succeeded
2014/11/7:15:45:01 User K551LN PageOpen MaintCompleteDialog
2014/11/7:15:45:08 User K551LN === Setup ended ===
2014/11/7:16:00:26 User K551LN === Setup started on K551LN by User ===
2014/11/7:16:00:26 User K551LN Launch
2014/11/7:16:00:38 User K551LN === Setup ended ===
2014/11/7:16:00:27 User K551LN === Setup started on K551LN by User ===
2014/11/7:16:00:27 User K551LN Launch
2014/11/7:16:00:34 User K551LN PageOpen LaunchDialog
2014/11/7:16:00:45 User K551LN PageOpen LicenseDialog
2014/11/7:16:00:48 User K551LN PageOpen ProductInfoDialog
2014/11/7:16:00:50 User K551LN PageOpen ProductSelectionDialog2
2014/11/7:16:00:53 User K551LN PageOpen FullProgressDialog
2014/11/7:16:00:53 User K551LN Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2014/11/7:16:01:01 User K551LN Install .NET Framework Runtime 4.0 Language Pack Succeeded
2014/11/7:16:01:01 User K551LN Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/11/7:16:01:19 User K551LN Install DirectX Runtime Succeeded
2014/11/7:16:01:19 User K551LN Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:16:02:27 User K551LN Install Autodesk Material Library 2012 Succeeded
2014/11/7:16:02:27 User K551LN Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:16:02:49 User K551LN Install Autodesk Content Service Succeeded
2014/11/7:16:02:56 User K551LN Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\User\AppData\Local\Temp\_AI7BA6.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:16:08:41 User K551LN Install AutoCAD® 2012 Succeeded
2014/11/7:16:08:45 User K551LN Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI7BA6.tmp\_la857.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:16:11:48 User K551LN Install AutoCAD® 2012 Language Pack Succeeded
2014/11/7:16:11:49 User K551LN Installing Autodesk® Inventor® Fusion 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\InventorFusion\InventorFusion.mst;C:\Users\User\AppData\Local\Temp\_AI7BA6.tmp\x64\InventorFusion\InventorFusion-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:16:14:43 User K551LN Install Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/7:16:14:44 User K551LN Installing Autodesk Inventor Fusion Language Pack: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI7BA6.tmp\_la90CB.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:16:14:44 User K551LN Install Autodesk Inventor Fusion Language Pack Failed Installation aborted, Result=1624
2014/11/7:16:15:19 User K551LN Rollback Autodesk® Inventor® Fusion 2012 Succeeded
2014/11/7:16:16:05 User K551LN Rollback AutoCAD® 2012 Language Pack Succeeded
2014/11/7:16:17:41 User K551LN Rollback AutoCAD® 2012 Succeeded
2014/11/7:16:17:58 User K551LN Rollback Autodesk Content Service Succeeded
2014/11/7:16:18:50 User K551LN Rollback Autodesk Material Library 2012 Succeeded
2014/11/7:16:18:50 User K551LN Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/11/7:16:18:50 User K551LN Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
